UART Question
fuzzy
UART Question
PostPosted: Mon Feb 26, 2007 11:50 am     Reply with quote
I configured my PIC16F88 with hw uart. I need only RX pin and i'd like to use TX pin as Output.
Is it possible to do?
I found some problems, because if i set TX pin as Uart TX my device works fine, but pin RB5 is always 5V.
If i try to exclude pin B5 from uart, compiler compile my code. but device stops working.
Can you help me??
PostPosted: Mon Feb 26, 2007 11:55 am     Reply with quote
Here is a long thread on the topic. See if this helps:
http://www.ccsinfo.com/forum/viewtopic.php?t=28605
