Using ccstcp/ip stack
tranz
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Sat Feb 24, 2007 7:58 pm     Reply with quote
Hello guys I am using the 18F6722 with the ccs compilers tcp/ip stack. but when I call this stack the following error appears
1)Error 100"c:\..\ccstcpip.h" line...: USE parameter velue i out of range NOT a number:PIN_C6
..the code at which it shows the error is
2)Error 128"c:\..\ccstcpip.h" line...: A #DEVICE required before this line.
..the line on which this error occurs is
#byte PORTA = 0xF80
Since this is a TCP/IP stack and can be used with all the PICs compatable to use this code.
3)Error 119"c:\..\ccstcpip.h" line...:"You need to define your custom hardware."
This line was used with the #error statement, although the syntax seems to be correct. The error still shows.
Can you guys help?
Re: Using ccstcp/ip stack
PostPosted: Sat Feb 24, 2007 9:31 pm     Reply with quote
1)Error 100"c:\..\ccstcpip.h" line...: USE parameter value is out of range NOT a number:PIN_C6
#byte PORTA = 0xF80
Can you guys help?
...some errors in the description in the poat as well :D
PostPosted: Tue Feb 27, 2007 1:25 pm     Reply with quote
Put the include file for the device before the include file of the TCP/IP stack.
