Hi
I have two LDR connected to two analog ports op PIC16F876 in the potential divider sort. I want to compare the two LDR values (I mean the voltage) and then give appropriate signal to drive the mtor. I am using CCS C compiler. Any suggesstion???????
Many Thanks
Quium
asmallri
Joined: 12 Aug 2004 Posts: 1642 Location: Perth, Australia
Posted: Sat Feb 24, 2007 11:29 pm
You should be away that the transfer characteristics between LDRs even in the same batch can vary significantly. You may need to perform some form of calibration on them if you want fine or medium level of granularity for the delta. _________________ Regards, Andrew
