Has anyone ported the USB 1.22 example from MICROCHIP (HI-Tech) to CCS (PCM)? It seems that the .as files are NG for PCM. Is this correct? The usb_ch_9.as file alone is 74k and the thought of modifying them all is overwhelming.
I might be missing something here. This is my first experience with PICs and PCM. I intend to use a 16C765. Any input would be appreciated.
___________________________
Original Post ID: 1100
Zaccy Guest
Usb problems too
Posted: Fri Feb 23, 2007 9:12 pm
I have some problems with the ex_usb_hid.c example -
All the good examples are the ones using the Hi-tech compiler and they work on my chip, but using the ex_usb_hid.c example, there is no life at the enumeration and stuff..
So I'm also looking for the ultimate example interfacing to the USB using CCS compiler (Cause the Hi-tech compiler is way to expensive :-() and the CCS compiler doesn't like the HI-tech syntax
