write_ext_eeprom
Vefa
write_ext_eeprom
PostPosted: Tue Feb 20, 2007 4:03 pm     Reply with quote
Hi Everyone,
Does anyone have any idea why the following simple code would not work?
#include <18F8722>
#include <24515.c>
#include <stdlib.h>
#include <math.h>
#fuses HS,NOWDT,NOPROTECT,PUT,NOLVP
#use delay(clock=10000000)
#use rs232(baud=2400, xmit=PIN_A4, rcv=PIN_A5, stream=PC, ERRORS)
#define LED PIN_F0
   short int c=5;
   long address=10;
      fputc('a', PC);
      delay_ms(50);
      init_ext_eeprom();
      WRITE_EXT_EEPROM(address, c);
      delay_ms(50);
      fputc('*', PC);
} // end of main
It prints an "a" and waits there.
PostPosted: Tue Feb 20, 2007 4:09 pm     Reply with quote
Follow standard debugging procedures. Comment out lines of code
until you find out which line is causing the problem.
Vefa
PostPosted: Tue Feb 20, 2007 4:30 pm     Reply with quote
write_ext_eeprom line does not work. I checked my hardware. Am I missing something in the code?
PostPosted: Tue Feb 20, 2007 4:49 pm     Reply with quote
Do you have pull-up resistors on the each of the SDA and SCL lines ?
You need them for i2c. You can use 4.7K.
Also, I noticed something else about your program.
short int c=5;
Did you know that in CCS, a 'short' is a 1-bit variable ?
Download the CCS manual and look at page 23 (page 33 in the Acrobat
reader). It shows a table with the sizes of the data types.
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Vefa
PostPosted: Tue Feb 20, 2007 8:06 pm     Reply with quote
Thanks PCM programmer. I have the pull ups. I used int instead of short int. Thanks for the manual as well. Do you agree that I have a hardware problem? or should I try low level programming as in
i2c_start();
   i2c_write(control_byte | WRITE); // write
   i2c_write(high_byte);
   i2c_write(low_byte);
   i2c_start(); // restart
   i2c_write(control_byte | READ); // read
   low_byte = i2c_read(0); // no ack
   i2c_stop();
   return (low_byte);
PostPosted: Tue Feb 20, 2007 8:41 pm     Reply with quote
What PIC pins are you using for the EEPROM ?
What value of resistors are you using for the pull-ups ?
Vefa
PostPosted: Wed Feb 21, 2007 10:19 am     Reply with quote
C3, and C4. Pull-ups are 4K. I tried 3 different 24FC515 EEPROM chips. I did a continuity test. Everything in the hardware end seems to be in good /working condition. I am using a friend's circuit and he successfully used the circuit with a similar code. Still, I can't get the code that I initially posted to work. I am a newbie and I am not sure if I am missing a very simple thing.
PostPosted: Thu Feb 22, 2007 2:27 pm     Reply with quote
Post your compiler version. I'll compile the code and look at the .LST file.
Vefa
PostPosted: Fri Feb 23, 2007 9:07 am     Reply with quote
My compiler is PCH version 3.249.
When I compile the code with the compiler on my friend's computer, it works! When I compile it with mine it does not. We have the same compiler. I am going to try reinstalling the compiler. Any suggestion?
PostPosted: Fri Feb 23, 2007 9:18 am     Reply with quote
I posted about this quite recently.
There is a problem with certain chips, when using the hardware I2C, and a 'repeated start' command. For some reason, on these, the ACK never gets seen, and the driver will hang. Either use the software I2C (FORCE_SW), or add a 'I2C_STOP', before the restart.
Vefa
works!
PostPosted: Fri Feb 23, 2007 9:47 am     Reply with quote
I checked the lst file. I saw the following statement:
#ifndef EEPROM_SDA
.................... #define EEPROM_SDA  PIN_B1
.................... #define EEPROM_SCL  PIN_B0
My sda and scl pins are C3 & C4. I then realized if I defined the sda and scl pins before including the 24515.c file then it would work. That's what I did. Following is the code that works:
#include <18F8722>
#include <stdlib.h>
#include <math.h>
#define EEPROM_SDA PIN_C4
#define EEPROM_SCL PIN_C3
#include <24515.c>
#define LED PIN_F0
main()
   // EEPROM
   long address=0;
   output_high(LED);
   delay_ms(1500);
   output_low(LED);
         if(address<65535>255) output_high(LED);
         else output_low(LED);
} // end of main
Thanks to everyone.
Special thanks to PCM Programmer.
