Imanjl
TIMER1 with 32khz osc doesnt work |
Posted: Fri Feb 23, 2007 8:00 am |
I used TIMER1 with 32.768 khz external crystal and try to get 1 second
duration timer but after some test and measurements finally I find out that this 32khz oscillator isnt calibrated or maybe there is something wrong with my code cause everytime I run this code on pic it gaves me a different result and timing .besides If i use internal osc for timer1 everything is alright .
uP is PIC16f877A operates on 20MHZ and compiler ver :3.249
here is my code :
int16 k;
int8 i;
//with 32.768khz osc it must gaves us 30.5uS resolution with 2s overflow
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT);
//this program is just for test and my original code is something else
loop;
set_timer1(32766); // (65536/2)=32766 : 1s delay()
delay_ms(950); // 950ms (timer has 50ms to overflow)
k=get_timer1();
printf("\ntimer1=%lu\n\r",k);
goto loop ;
On my serial port the result is something like this :
timer1=65432
timer1=65331
timer1=12
timer1=65510
these numbers must be the same what is the problem ? anyone has anyother suggestion? |
Posted: Fri Feb 23, 2007 9:13 am |
There are significant problems with what you are doing. The big one is that running off an external clock, timer1, is now asynchronous to the internal CPU clock. When this is the case, you cannot just read and write the timer. To write it, you need to stop the timer, write the required value, and then restart the timer. Otherwise indeterminate resuts may occur, depending on when in the write, the chip counts. There is a similar problem when reading, where if the counter changes between reading the high byte, and the low byte, a 'silly' result can be seen. Look at the timer1 reference notes on the Microchip site, to get details of the code needed.
Imanjl
Posted: Fri Feb 23, 2007 4:26 pm |
I tried to stop timer during write process and read process,but still
the problem didnt solve .At this time the results is closer to each other than the first time :
timer1=65421
timer1=65395
timer1=65345
timer1=65414
timer1=65395
timer1=65368
Code: | Loop:
output_high(pin_a0);
setup_timer_1(T1_DISABLED);
set_timer1(32768);
delay_ms(950);
k=get_timer1();
Goto loop; |
rnielsen
Posted: Fri Feb 23, 2007 5:51 pm |
Doing things this way will always have inaccurate results. Depending on what other things you have going on, other interrupts, routines, and so on.... the PIC shares time with everything that's going on. Setting the register to a known value won't always get you the same value at the end. If you have another timer running it will take up a certain amount of time and will cause your values, from the get_timer() function to vary. If you need accurate timing then you will need to allow the timer to roll over, causing an interrupt, and have that flag whatever you want done.
There are other posts on people trying to manipulate the timers the way you are and just can't seem to get it to be very accurate.
Ronald |
Posted: Fri Feb 23, 2007 5:54 pm |
I ran your program (shown below) on a PicDem2-Plus and I got this:
Quote: |
61622
63899
63899
63899
63899
63899
63900
63900
63900
63899
Code: | #include <16F877A.H>
int16 k;
int8 i;
for(i = 0; i < 10; i++)
set_timer1(32768);
delay_ms(950);
k = get_timer1();
printf("%lu\n\r", k);
Imanjl
Posted: Sat Feb 24, 2007 2:59 am |
rnielsen wrote: | If you need accurate timing then you will need to allow the timer to roll over, causing an interrupt, and have that flag whatever you want done. |
I wrote a new program without using get_timer1(); at this time when timer overflows(1s) it generates an interrupt .but still 1 second isnt accurate . This program generates 1 second in about 850-950mS .
Code: | #int_TIMER1
TIMER1_isr(){
set_timer1(32768);
count++;}
{int16 k;
int8 i;
set_timer1(32766);
loop:
printf("\ntimer1=%lu\n\r",count);
goto loop ;} |
hi pcm programmer ,ur result shows that the program works fine on Picdem2 cause (63900-32768)*30.5us=949ms .Maybe there is something wrong with my hardware according to microchip refrence manual,32.768 need two 33pf capacitors I use 30pf for c1 and c2 but I dont think it affects the result so much ,whats the Picdem2 caps value for timer1 ?
Besides the pic is on the bread board :
Quote: | Design Tips
2. You should ensure the your layout uses good PCB layout techniques so that noise does not couple onto the Timer1 oscillator lines. |
