Burst Transient and I2C bus
Fabri
PostPosted: Thu Feb 22, 2007 11:29 am     Reply with quote
I've a problem with RTC PCF8563 and Burst transient.
My micro read rtc every 100us and after a burst on power supply I found the date and time changed. The new date and time isn't bcd format and really strange.
I tryed to supply PCF with only battery but the problem remain.
The micro don't do any kind of reset during test and all seem work fine.
Some any idea about ?
Regards,
Fabri
PostPosted: Thu Feb 22, 2007 1:56 pm     Reply with quote
Put a 0.1 uF (100 nF) capacitor between the Vdd pin and ground
on both the PIC and the PCF8563 chip. Put the capacitors very
close to the Vdd pins.
Add at least a 10 uF (16v) Tantalum capacitor on the output of your
voltage regulator. Use Tantalum, not Aluminum Electrolytic.
Fabri
PostPosted: Thu Feb 22, 2007 2:47 pm     Reply with quote
Hi PCM,
I did it, in my layout there's capacitors really near PIC18 and PCF8563.
Any other suggestion ?
Regards,
PostPosted: Thu Feb 22, 2007 2:56 pm     Reply with quote
Are you really trying to read the date and time every 100 us ?
Try changing it to every 1 second.
Fabri
PostPosted: Thu Feb 22, 2007 3:13 pm     Reply with quote
I'm sorry,
I read RTC every 100ms. I used the same way in other software with PIC16 in assembler without any problem. I read only one register at time.
Do you think I read many time the RTC ?
PostPosted: Thu Feb 22, 2007 3:16 pm     Reply with quote
What driver program are you using to talk to the PCF8563 ?
Did you write it, or is it available on the net ?
Fabri
PostPosted: Thu Feb 22, 2007 3:36 pm     Reply with quote
I wrote the driver by myself using datasheet of PCF8563 and after wrote the assembler one.
I use this routine to read every single register of PCF8563
#use I2C(MASTER,sda=PIN_C4,scl=PIN_C3,FORCE_HW,slow,RESTART_WDT)
#define address_rtc_read   0b10100011
#define address_rtc_write   0b10100010
int read_rtc_register(int address_rtc){
int dato_locazione_rtc;
int mo;
   i2c_start();
   i2c_write(address_rtc_write);
   i2c_write(address_rtc);
   i2c_start();
   i2c_write(address_rtc_read);
   dato_locazione_rtc =i2c_read();
   mo=i2c_read(0);
   i2c_stop();
   return dato_locazione_rtc;
