Stability issues with ADC?
Goto page Previous  1, 2
Neutone
PostPosted: Thu Feb 22, 2007 12:11 pm     Reply with quote
sonicfire wrote:
Okay, here's a new problem. I've been informed that I need to output a 500KHz PWM signal, instead of a 20KHz signal. I manipulated the code a little bit and was able to get an output of 500KHz, but now the output is unstable again and very sensitive to the analog input. In other words, if I input as little as .5V, the duty cycle is now 100% (where as for the 20KHz, 5V would max out at 50%). I also tried introducing a 500uS delay into the loop, with little added benefit. Here's the code:
#if defined(__PCM__)
#include <16F877.h>
#use delay(clock=10000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BRGH1OK)
#elif defined(__PCH__)
#include <18F452.h>
#endif
void main() {
   INT16 value;
   setup_ccp1(CCP_PWM);   // Configure CCP1 as a PWM
  setup_timer_2(T2_DIV_BY_1, 4, 1);  //output at 500KHz
  setup_port_a(ALL_ANALOG);
  setup_adc(adc_clock_internal);
  set_adc_channel( 0 );
  while( TRUE ) {
    value=read_adc();
    set_pwm1_duty(value);          // This sets the time the pulse is
                                   // high each cycle.  We use the A/D
                                   // input to make a easy demo.
                                   // the high time will be:
                                   //  if value is LONG INT:
                                   //    value*(1/clock)*t2div
                                   //  if value is INT:
                                   //    value*4*(1/clock)*t2div
                                   // for example a value of 30 and t2div
                                   // of 1 the high time is 12us
                                   // WARNING:  A value too high or low will
                                   //           prevent the output from
                                   //           changing.
This is a scaling issue. you need to scale the value you read from the ADC before you load it into the PWM. Your ADC is configured to return a value ranging from 0 to 1023 representing 0 to 100%. The PWM is configured to accept a value ranging from 0 to 19 representing 0 to 100%.
The scaling factor is 20/1024 or 0.01953125
To scale without using floating point math:
change
value=read_adc();
to
value=(read_adc()*20)/1024;
PostPosted: Thu Feb 22, 2007 12:50 pm     Reply with quote
His A/D is not configured for 10-bit mode. The compiler defaults to
8-bit mode.
Here's the code from the .LST file for the posted program
The A/D is configured for left-justified output. Then, only
the MSB of the result is read, from the ADRESH register.
This discards the lower two bits. The posted program
puts this 8-bit result into the LSB of a 16-bit variable.
The code below clears the MSB of the variable.
......     value=read_adc();
002F:  BSF    ADCON0.2
0030:  BTFSC  ADCON0.2
0031:  GOTO   030
0032:  MOVF   ADRESH,W
0033:  CLRF   value+1
0034:  MOVWF  value
sonicfire
PostPosted: Thu Feb 22, 2007 1:05 pm     Reply with quote
I now understand why the PWM only accepts values from 0 to 19, but I'm not sure why the A/D converter returns a number 0 to 1023. I tried implementing the change with no success. The scope output is unintelligible. I can manually set the A/D value from 0 to 20 and get satisfactory results, but I can't seem to read an input voltage (0 to 5V from a 5K pot) with the same success.
If my A/D converter is defaulting to 8bit read, how can I change it to read 10bits in my C code?
PostPosted: Thu Feb 22, 2007 1:32 pm     Reply with quote
#include <16F877.H>
#device adc=10   // Add this line in this exact location.
sonicfire
PostPosted: Thu Feb 22, 2007 1:33 pm     Reply with quote
thanks
sonicfire
PostPosted: Thu Feb 22, 2007 1:40 pm     Reply with quote
You guys were both dead on! I now understand the scaling factor and that works quite well. The 10bit adc seems to have fixed a lot of problems as well. Thank you.
Page 2 of 2
