Markdem
MIDI data problem |
Posted: Wed Feb 21, 2007 11:47 pm |
hi All, i am tring to make a MIDI to USB converter. I have the hardware all setup OK, but when I start reciving the data, I only get the first byte. the other two bytes are never what they sould be, and mostly come out as 0x00.
Sometimes, even the first byte will be somthing that it should not be.
The first byte of data should be a 0x90 for a note on, and 0x80 for a note off. This sometimes happends, but the next byte should be 0x60 for middle C, but it almost always is 0x00. Sometimes I will get 0x40.
The following is the code i am using;
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOBROWNOUT
#use delay(clock=48000000)
#use rs232(baud=31250, BITS=8, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#define USB_CON_SENSE_PIN PIN_D1
#include <STDLIB>
#include <usb_cdc.h>
int1 RXReady;
int i;
int BeatMask[33];
int MIDIData[4];
#int_rda
void MIDIIn()
RXReady = TRUE;
MIDIData[0] = getc();
MIDIData[1] = getc();
MIDIData[2] = getc();
RXReady = 0;
usb_init_cs();
usb_task();
enable_interrupts(INT_RDA);
usb_task();
if (RXReady)
RXReady = FALSE;
if(bit_test(MIDIData[0],7)) //Check to see if the first byte is the start of a MIDI message
printf(usb_cdc_putc,"%X, %X, %X\r\n",MIDIData[0], MIDIData[1], MIDIData[2]);
RXReady = FALSE;
Also, you may notice that i am doing serial comms inside the ISR, and i know that is wrong, but if i just try to set the RXReady flag, the code will never start to get the data from the buffer.
Lastly, i did have a for loop for the serial comms, but removed it for testing.
I think I might have some problems with data buffing, but i thought that the pic had a 3 byte hardware buffer, which would mean i should never lose data.
Can anyone see what i am doing wrong.
Thank you for you help. |
mbge5amw
Joined: 13 Dec 2004 Posts: 15 Location: Yorkshire, UK
Posted: Thu Feb 22, 2007 2:37 am |
one potential problem I could see would be if the unit starts running after the MIDI stream has begun, or if a byte is lost, in this case the unit may not read characters 0,1,2 of the MIDI stream, instead it may read 1,2,0 or 2,0,1.
I would suggest reading 1 character at a time in the interrupt routine (otherwise it will be stuck in there from reception of the first character to reception of the third character)
In this interrupt routine check the MSB and if high then reset a character counter to 0, otherwise increment the character counter.
When your character counter indicates three characters have been received and you check that the first character had valid synch bit set a flag to get the main routine to decode the data.
If you think there may be a chance that you are off doing USB routines for long enough for a new character to come in for the start of the next MIDI command before you have processed this current command then it may also be wise to copy all 3 bytes to a separate buffer at the end of the ISR.
HTH
Andy |
