Dot matrix led 8x8 with 16f628 and 74hc595
E_KARVELAs
PostPosted: Tue Feb 20, 2007 12:33 am     Reply with quote
HI
My name is Evagoras ''sorry for my bad English''
i make this routine for showing the message ''from Evagoras electronic enginiering''
well the circuit i make is working but the scrolling is going across the 74hc595.
i mean it is not goint through the 74hc138 as normaly it should be,but it's going through the 74hc595 as i'm puting the byte out...
This is a problem cus i can't put further 595 for more matrix.
i'm new to ccs c ,now learnig to college maybe i done something wrong with the code i came up!!!
it's simply so is no difficul to read...
i have two cuestions:
first: what i'm doing wrong with the scrolling code i realy need to fix this so i can put more 595 for suporting more matrix
second: im trying to make a rutine with statement (switch() case ) to search the characters and not puting then like the code i make ,so any opinion it woud be my pleasure to hear..
#include <16F628.h>
#fuses XT,NOWDT,NOPUT,NOBROWNOUT,NOMCLR,NOLVP
#byte PORTB = 0x06
#byte PORTA = 0x05
#define    DATA      PIN_B4
#define    LATCH    PIN_B5
#define   CLK         PIN_B6
long counter=0x00,  i,PLK=0X00;
long m=0x00,  D=(0x00),pointer=0x00;
long   adrs;
 const byte  DIG[]={
0x10,0x7e,0x90,0x80,0x40,0x00,   // f
0x3e,0x10,0x20,0x20,0x10,0x00,   // r
0x1c,0x22,0x22,0x22,0x1c,0x00,   // o
0x3e,0x20,0x18,0x20,0x1e,0x00,   // m
0x00,0x00,0x00,0x00,0x00,0x00,
0xfe,0x92,0x92,0x92,0x82,0x00,   // E
0x38,0x04,0x02,0x04,0x38,0x00,   // v
0x04,0x2a,0x2a,0x2a,0x1e,0x00,   // a
0x30,0x4a,0x4a,0x4a,0x7c,0x00,   // g
0x12,0x2a,0x2a,0x2a,0x04,0x00,   // s
0x00,0x82,0xfe,0x02,0x00,0x00,   // l
0x1c,0x2a,0x2a,0x2a,0x18,0x00,   // e
0x1c,0x22,0x22,0x22,0x04,0x00,   // c
0x20,0xfc,0x22,0x02,0x04,0x00,   // t
0x3e,0x10,0x20,0x20,0x1e,0x00,   // n
0x00,0x22,0xbe,0x02,0x00,0x00,   // i
 void output_74hc138()      // void for switching the next arrow of 74hc138
         set_tris_a(0x00);
         PORTA=PLK;
          ++PLK;
if  (PLK>0X07)   {
            PLK=0X00;
         output_high(LATCH);
          output_low(LATCH);
          delay_us(2000);              //give same time for show the row
void main() {
   set_tris_b(0x00);
  PORTB=(0x00);
  PORTA=(0x00);
       for(;;){
adrs = counter + pointer;
++counter;
if (counter>7){
         counter=0;
           ++m;
        if   (m>4)   {   //     m :how many time  will be show the same frame
                ++pointer; //    if the frame show 4 time then get next frame for show
                  m=0x00;   //     show next frame 4 time  ,and again...
      D=DIG[adrs];                                  //register wich is going to 74hc595
    for(i=0;i<8;++i) {                                  // Clock out bits from the eo array
                    if ((D & 0x80)==0)               //
                         output_low(DATA);         //
                    else                                   //  GETING THE DATA  READY TO 74HC595
                        output_high(DATA);         //
                         D=D<<1;                       //
                        output_high(CLK);            //CLOCK THE 74HC595
                        output_low(CLK);             //
         void output_74hc138();                       // SWITCH THE NEXT ROW ON OF 74HC138
if  (adrs>203)    {                                // if adrs is at the end  of  the
                                                           //table start from the begining again
                adrs=(0x00);                    //
---- GREECE ----
E_KARVELAs
PostPosted: Tue Feb 20, 2007 1:36 am     Reply with quote
sorry about the schematic it is not the best picture i make it to show what is going wrong with scrolling
As i show here the scrolling is going wrong way...
there is somehing wrong with my code i can't figur out
---- GREECE ----
