please help!!!
E_KARVELAs
please help!!!
PostPosted: Sun Feb 18, 2007 11:57 am     Reply with quote
hi
i got the follow table..error!!!!! Confused
---- GREECE ----
PostPosted: Sun Feb 18, 2007 12:20 pm     Reply with quote
For the 16F PICs (with the PCM compiler), const arrays are limited to
256 ROM words. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=25483&highlight=const+array+256
You need to break up the large array into two or more smaller arrays,
which have only 256 elements in each array. Then write some code
to check the index value, and use the correct array based upon the
index value.
Also, when you start a new topic, you should use a better title than
"please help". Almost all posts are asking for help. We know that.
Use a descriptive title such as "Problem with size of const array".
E_KARVELAs
PostPosted: Sun Feb 18, 2007 2:48 pm     Reply with quote
hi
i been change the code as follow:
i want to change the 6 byte of table every time the ch change
but i have a error:
why???
*** Error 51 "C:\Documents and Settings\Evagoras.EVAGORASHP\Desktop\mplab_C_TO_hex\matrix.c" Line 19(7,12): A numeric expression must appear here
 ch=getch();
switch( ch)
   case 'A':
      const int  DIG[6]={0x7e,0x88,0x88,0x88,0x7e,0x00,};          //A    <--here is the error
   case 'B':
      const int  DIG[6]={0xfe,0x92,0x92,0x92,0x6c,0x00,};       //B  <--and here
  case 'Z':
       const intDIG[6]={................................}
---- GREECE ----
PostPosted: Sun Feb 18, 2007 4:05 pm     Reply with quote
You can't stick declarations in the middle of a switch() statement like that.
Also, in my post I said to break up the large array into smaller arrays
that have at most, 256 elements. I didn't say to break them up into
one million little arrays. I meant for you to do something like the code
shown below. The test program has the following output, which shows
that the segment data is correctly accessed from the two arrays:
00 00 00 00 00 00
04 08 10 20 40 00
7C 8A 92 A2 7C 00
40 80 8A 90 60 00
#include <16F877.H>
const int8 DIG_0[16][6] = {
0x00,0x00,0x00,0x00,0x00,0x00, // space
0x00,0x00,0xfa,0x00,0x00,0x00, // !
0x00,0xe0,0x00,0xe0,0x00,0x00, // "
0x28,0xfe,0x28,0xfe,0x28,0x00, // #
0x24,0x54,0xfe,0x54,0x48,0x00, // $
0xc4,0xc8,0x10,0x26,0x46,0x00, // %
0x6c,0x92,0xaa,0x44,0x0a,0x00, // &
0x00,0xa0,0xc0,0x00,0x00,0x00, // '
0x00,0x38,0x44,0x82,0x00,0x00, // (
0x00,0x82,0x44,0x38,0x00,0x00, // )
0x28,0x10,0x7c,0x10,0x28,0x00, // *
0x10,0x10,0x7c,0x10,0x10,0x00, // +
0x00,0x0a,0x0c,0x00,0x00,0x00, // ,
0x10,0x10,0x10,0x10,0x10,0x00, // -
0x00,0x06,0x06,0x00,0x00,0x00, // .
0x04,0x08,0x10,0x20,0x40,0x00, // /
const int8 DIG_1[16][6] = {
0x7c,0x8a,0x92,0xa2,0x7c,0x00, // 0
0x00,0x42,0xfe,0x02,0x00,0x00, // 1
0x42,0x86,0x8a,0x92,0x62,0x00, // 2
0x84,0x82,0xa2,0xd2,0x8c,0x00, // 3
0x18,0x28,0x48,0xfe,0x08,0x00, // 4
0xe5,0xa2,0xa2,0xa2,0x9c,0x00, // 5
0x3c,0x52,0x92,0x92,0x0c,0x00, // 6
0x80,0x8e,0x90,0xa0,0xc0,0x00, // 7
0x6c,0x92,0x92,0x92,0x6c,0x00, // 8
0x60,0x92,0x92,0x94,0x78,0x00  // 9
0x00,0x6c,0x6c,0x00,0x00,0x00, // :
0x00,0x6a,0x6c,0x00,0x00,0x00, // ;
0x10,0x28,0x44,0x82,0x00,0x00, // <
0x00,0x6a,0x6c,0x00,0x00,0x00, // =
0x10,0x28,0x44,0x82,0x00,0x00, // >
0x40,0x80,0x8a,0x90,0x60,0x00  // ?
void display_data(int8 c)
int8 i;
int8 digit_data[6];
if((c < ' ') || (c > '?'))
   return;
if(c < '0')
   memcpy(digit_data, Dig_0[c - ' '], 6);
else if (c < '@')
   memcpy(digit_data, Dig_1[c - '0'], 6);
for(i = 0; i < 6; i++)
    printf("%X " , digit_data[i]);
printf("\n");
char c;
c = ' ';
display_data(c);
c = '/';
display_data(c);
c = '0';
display_data(c);
c = '?';
display_data(c);
One more thing. When you post code, make sure that you disable HTML.
There is a tickbox below the posting window to do this. It looks like this:
x Disable HTML in this post
E_KARVELAs
PostPosted: Sun Feb 18, 2007 5:29 pm     Reply with quote
PostPosted: Sun Feb 18, 2007 5:45 pm     Reply with quote
I've done enough on this thread.
