Device 18f4520
Paul
Device 18f4520
PostPosted: Fri Feb 16, 2007 10:28 am     Reply with quote
Does someone have a 18f4520.h , I need to use this Pic but I don't have it at my device . h file list.
Thank you
PostPosted: Fri Feb 16, 2007 10:41 am     Reply with quote
Won't help you.
The .h file, _does not add a PIC to the devices supported_. This has been covered dozens of times here. You need one of the following:
1) Buy a latter compiler with support for the chip.
2) If you have the PCW package, use the device editor, and add support for the chip, by copying somthing close, and editing this.
All the .h file gives are standard defines. They don't even change much between chips.
Paul
PostPosted: Fri Feb 16, 2007 11:05 am     Reply with quote
Do you know if is there a version of CCS that contains PIC18f4520?
Best wishes
PostPosted: Fri Feb 16, 2007 11:23 am     Reply with quote
Not sure exactly when it was added, but around 3.220. About March 2005. Works fine in 3.249. Any PCH, or PCWH release after this point has support.
