PIC18F2431 X A/D
alcomen
PIC18F2431 X A/D
PostPosted: Thu Feb 15, 2007 7:17 am     Reply with quote
I am using PIC18F2431 for the first time. Somebody possess an example of as to configure the A/D for this chip?
Somebody obtained 200ksps converter?
Alessandro
PostPosted: Thu Feb 15, 2007 10:33 pm     Reply with quote
I don't have this PIC to test, but I think the following program will
demonstrate basic operation of the A/D. It should display values
from 0x000 to 0x3FF for an input of 0v to +5v on the AN0 pin.
#include <18F2431.h>
#device adc=10
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
int16 result;
setup_adc_ports(sAN0 | VSS_VDD);
setup_adc(ADC_CLOCK_DIV_16);  // For 20 MHz crystal
set_adc_channel(0);
delay_us(20);
   result = read_adc();
   printf("%LX\n\r", result);
alcomen
PostPosted: Tue Feb 20, 2007 7:42 pm     Reply with quote
Ok
I tested in my house your code. It's right. Tomorrow I go to test in the my job with oscilloscope for the time test acquisition.
Alessandro
alcomen
PostPosted: Fri Feb 23, 2007 5:47 am     Reply with quote
I got 155ksps.
I donī understand why my code only execute the interrupt.
The exemple:
#device adc=10
#int_timer1
void isr()
set_timer1(65534);
int16 result;
set_adc_channel(0);
delay_us(20);
setup_timer_1(T1_internal);
set_timer1(65534);
enable_interrupts(int_timer1);
enable_interrupts(global);
This dont print in serial, only read the A/D. Why??????
Alessandro
