Write Program EEPROM Question
nurquhar
PostPosted: Wed Feb 14, 2007 11:44 pm     Reply with quote
I am using write_program_eeprom() as shown below to write a 4 byte unique ID number into memory (they are actually written as RETLW's to patch the code). I am sometimes seeing a corruption problem with the values when I check them by reading the chip back with my ICD or a bit of dump code.
I have a TIMER0 interrupt running will this be causing the problem ? I thought I had seen here somewhere that internally the function disables interrrupts while it does its writes. Is this true or should I always use the GLOBAL enable/disable interrupt around the write function ?
Now I am using PCM v3.249 with the 16F876A (therefore getenv(“FLASH_ERASE_SIZE”) = (“FLASH_WRITE_SIZE”)) and so the write_program_eeprom() should be erasing the two byte value before it writes.
#define ROM_UID_BASE   0x1FF7
#define   RETLW_INST      0x3400
void writeEepromUid(uint16 adr, uint16 *dat)
   int i ;
   for (i = 0 ; i < 4 ; i++, adr++) {
      write_program_eeprom (adr, dat[i]) ;
      delay_us(50) ;
void BuildEepromUid(uint32 val, uint16 *dat)
   int i ;
   uint8 b ;
   for (i = 0 ; i < 4 ; i++) {
      b = val & 0x000000FF ;
      // Use RETLW instruction (3400 = 00)
      dat[i] = RETLW_INST | b ;
      val >>= 8 ;
.....the bits from main........
uint16 uid_dat[4] ;
uint32 val32 ;
if (change) {
   BuildEepromUid(val32, uid_dat) ;
   writeEepromUid(ROM_UID_BASE, uid_dat) ;
   printf(myputc, "New UID Set\r\n") ;
} else {
   printf(myputc, "No change made\r\n") ;
PostPosted: Thu Feb 15, 2007 12:41 am     Reply with quote
Your posted code is corrupted because you didn't disable HTML.
Please edit your post and paste in a fresh copy of the code.
Then select the tickbox just below the posting window to disable
HTML before pressing the Submit button.
nurquhar
PostPosted: Thu Feb 15, 2007 1:19 am     Reply with quote
It looked ok when I previed it. However I have re-posted the code and and disabled HTML as you suggested.
Regards
Neil
Got any perls of wisdom on write_program_eeprom() ?
