Analog input and Modbus
Storic
PostPosted: Mon Feb 12, 2007 5:53 pm     Reply with quote
Can Modbus communicate the analog value on an analog input? if it can, any idears where to start and the Modbus.
Andrew Confused
What has been learnt if you make the same mistake? Wink
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
Re: Analog input and Modbus
PostPosted: Mon Feb 12, 2007 6:32 pm     Reply with quote
No, MODBUS is a digital communication protocol.
You could digitize the analog value and send it in digital.
You could research differential analog lines.
Neutone
PostPosted: Tue Feb 13, 2007 12:12 pm     Reply with quote
Andrew Confused
Yes MODBUS uses registers for analog values. Input registers and holding registers are used to communicate 16-bit values. There are a few post with code for MODBUS in this forum. The MODBUS standard may be obtained from www.modbus.org. A lot of developer tools for the PC are available that support MODBUS at little to no cost. Most industrial PLC equipment can also support MODBUS slave devices.
