I need to use fuses configuration INTIO2 with pic 18f series but I can't see on compiler manual how use FUSES command with that configuration
Thank You
Posted: Tue Feb 13, 2007 3:54 am
Which PIC?.
Look at INTRC_IO.
Microchip, changed their naming nomenclature for this configuration, and only use the 'INTIO2' name on half a dozen chips (8722, 6390 etc.), which support external RC with an IO pin as well. CCS use the old nomenclature.
