RTCC Problem
kocakaya
RTCC Problem
PostPosted: Sun Feb 11, 2007 2:14 pm     Reply with quote
Is this code cause deviation in RTCC time. If yes ? what can I do? My crystal is 4 Mhz internal
Waiting your help
#define high_start 1000
void akimgerilim()
int adcdeger;
set_adc_channel( 1 );
delay_us(1);
value = Read_ADC();
deger=(float)value/51.0;
value=deger;
delay_us(1);
set_adc_channel( 0 );
delay_us(1);
adcdeger=Read_ADC();
max=adcdeger*1.5;
delay_us(1);
void besli() {
OUTPUT_HIGH(PIN_D4);
delay_ms(200);
OUTPUT_LOW(PIN_D4);
delay_ms(200);
OUTPUT_HIGH(PIN_C5);
delay_ms(200);
OUTPUT_LOW(PIN_C5);
delay_ms(200);
OUTPUT_HIGH(PIN_D3);
delay_ms(200);
OUTPUT_LOW(PIN_D3);
delay_ms(200);
OUTPUT_HIGH(PIN_D2);
delay_ms(200);
OUTPUT_LOW(PIN_D2);
delay_ms(200);
OUTPUT_HIGH(PIN_C2);
delay_ms(200);
OUTPUT_LOW(PIN_C2);
delay_ms(200);
#INT_RTCC
void clock_isr() {
  high_count -= 1;
  akimgerilim();
   if(high_count==0)
   ++seconds;
   high_count=high_start;
   ahtoplam=ahtoplam+sah;
   ah=ahtoplam;
   if(seconds>=60)
   minute++;
   seconds=0;
   if(minute>=60)
   hour++;
   minute=0;
main()
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8|RTCC_8_bit);
do
besli();
}while(true);
PostPosted: Sun Feb 11, 2007 5:15 pm     Reply with quote
With a 4MHz crystal and
you will get 488.28125 interrupts per second, not 1000 interrupts as you have specified.
Even when you set high_start to 488 you will get almost 50 seconds deviation per day because of the rounding. For a really accurate clock have a look at http://www.ccsinfo.com/forum/viewtopic.php?t=26177
kocakaya
PostPosted: Sun Feb 11, 2007 11:47 pm     Reply with quote
How can I calcute this number? What is formula?
Do you think making floating point number division and calling akimgerilim() function in INT_RTCC make any problem? or make any delay in interrupt?
This system calculates amper hour per seconds so I must use this code in RTCC interrupt
When I use RTCC , Timer1 and Timer2 together the system works very slow.And RTCC count 1 minute in two minute .Why? do you think?
The code that I changed is below
#INT_RTCC
void clock_isr() {
  high_count -= 1;
  akimgerilim();
   if(high_count==0)
   ++seconds;
   [b]ahtoplam=ahtoplam+max/3600; [/b] "Max is Floating point number"
   if(seconds>=60)
   minute++;
   seconds=0;
   if(minute>=60)
   hour++;
   minute=0;
kocakaya
help
PostPosted: Mon Feb 12, 2007 4:27 pm     Reply with quote
anybody help me in this forum?
PostPosted: Mon Feb 12, 2007 5:06 pm     Reply with quote
Check the figure for timer0 in the datasheet of your PIC.
The timer is clocked with Fosc/4 divided by the number you set for the prescaler. An 8 bit timer will generate an interrupt every 256 clocks, a 16-bit timer every 65536 clocks.
This will give an interrupt rate of: 4MHz / 4 / prescaler 8 / 256 = 488.something Hz
Interrupt routines should always be as short as possible. Floating point calculation takes a lot of computing power, but I think you are here still save. Search this forum or internet for an explanation of 'scaled integers' this is much quicker and might be an option for you.
This is after you changed the 1000 to 488?
How should we know? You don't show the code for Timer1 and Timer 2.
