teekaytk
bootloader information needed |
Posted: Fri Feb 09, 2007 8:37 am |
hello
its the first time i am working with the bootloader. i want to use the example bootloader for the pic18f452 and pic18f4520
i have a few questions
is there a significance of the pin_b5 being used for boot load?
i want to modify it so that it no longer waits for the pin rather , if it gets data in the first two seconds then it puts in the new data otherwise it goes on to the application. is there a way to do this?
also i got the following error when i included the bootloader.h file in code to be bootloaded, any ideas how to resolve this
--- Info 300 "C:\Documents and Settings\tk31\Desktop\post.c" Line 1556(0,1): More info: Segment at 00000-004FE (0000 used) Priv
--- Info 300 "C:\Documents and Settings\tk31\Desktop\post.c" Line 1556(0,1): More info: Segment at 00500-00506 (0004 used) Priv
--- Info 300 "C:\Documents and Settings\tk31\Desktop\post.c" Line 1556(0,1): More info: Segment at 00508-07CBE (0000 used)
--- Info 300 "C:\Documents and Settings\tk31\Desktop\post.c" Line 1556(0,1): More info: Attempted to create: 00506-005B4 for ISR
*** Error 126 "C:\Documents and Settings\tk31\Desktop\post.c" Line 1556(0,1): Invalid ORG range
1 Errors, 2 Warnings.
thanks
TK |
teekaytk
Posted: Sun Feb 11, 2007 3:28 am |
anyone? |
Posted: Sun Feb 11, 2007 4:59 am |
No significance whatsoever.
Yes. However it brings the 'penalty', of a fairly long delay at boot, and obviously needs care to ensure that the code really is getting legitimate data.
Looks like you have included something else in front of bootloader.h. This must be the _first_ file included, after the chip configuration. Otherwise any routines defined in the other files will already be located in the reserved memory area.
teekaytk
Posted: Sun Feb 11, 2007 5:35 am |
thanks Ttelmah
this is the probably the second or third time you have helped me out. most appiciated. i shall check the position of the bootloader.h file to makesure it is the first one. thanks again
best regards
TK |
