vsmguy
[ot]Parallel port programmer ICSP Programmer |
Posted: Sat Feb 10, 2007 9:46 am |
Does anyone have schematics for a parallel port programmer which allows ICSP and proven to work with laptop parallel ports ? |
vsmguy
Posted: Sat Feb 10, 2007 12:07 pm |
Lots of people already viewed this thread but not a single person replied back
By the looks of this... I will be happy if I could get schematics to a USB based programmer (NOT an ICD2) which can do atleast 16f/18fs and not just 18f.
Now wait a moment... the design should be open/ nothing proprietary please.... such things become outdated very fast. |
kender
Posted: Sat Feb 10, 2007 6:31 pm |
You probably didn't get a response because like you already mentioned it is a bit of topic. Using Google it is very easy to find these schematics, I guessed you would try this when no answers came up. Using the keywords "PIC programmer schematic" I found lots of good links.
A very simple and proven schematic I found was: Byron Jeff's PIC Page. His Trivial LVP programmer is based on David Tait's programmer
Note that with an LVP programmer design you have to assing the PIC LVP-pin to be used for programming only, the pin is not available for normal I/O. That's why all commercial programmers are of the High Voltage type, they don't use the LVP pin, leaving one more pin free for your application. On Byron Jeff's page you will find an adaption to his schematic turning it into a High Voltage Programmer.
Hint: the 13V for a High Voltage programmer can be generated by a MAX232 driver chip. |
vsmguy
Posted: Sun Feb 11, 2007 7:15 am |
Oh no... I always google before asking questions...
The thing is I am asking specifically for a ICSP NONLVP Programmer which has WORKED on someone's laptop paralle port.
Of all the designs I saw, Microchip had a AN589 programmer which everyone likes to dislike.
I built one using a SN7407 and it did nothing.. I built my own 13v power supply using the 7812 with two 1n4148s to get the drop.
It did not work... the page I don't remember exactly.... if someone wants to verify I will fish it out.
The point is, I want to use a tested design.
Oh... and it should definitely program the 877a and 4550 |
