OSC 4xPLL How to setting?
micman
PostPosted: Sat Feb 10, 2007 3:18 am     Reply with quote
Hi all,
I have a doubt, the board is setting with crystal 10MHz and use 4xPLL.
Ok
but when I setting CCS oscillator , I must setting
#FUSES H4 //Ok! //High speed osc with HW enabled 4X PLL
and
#use delay(clock=10000000) //??
or
#use delay(clock=40000000) //?? 10Mhz x 4
Inserted into .h file:
#device ICD=TRUE
#device adc=8
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES DEBUG //Debug mode for use with ICD
PostPosted: Sat Feb 10, 2007 3:46 am     Reply with quote
The delay function 'cares' about the actual clock frequency, not how it is generated.
micman
PostPosted: Sat Feb 10, 2007 4:40 am     Reply with quote
thank you very mach
