#define for multiple statements
nazoa
PostPosted: Fri Feb 09, 2007 7:54 am     Reply with quote
I am unsure what the correct way is for defining multiple statements with #define. For example if I want to replace the following lines
output_low(PIN_C0);
output_low(PIN_C1);
with a single command called 'Shift', can I do the following;
#define Shift (output_low(PIN_C0), output_high(PIN_C1))
Then, in my code simply use it by typing 'Shift;'
The compiler does not generate an error but I would like to know if
this is the correct way to go about it.
Thanks.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Fri Feb 09, 2007 8:46 am     Reply with quote
What you are desribing is called a "macro". Here's how you define it
// empty parentheses are optional, if you are not passing args to your macro
// by convention names of #defines, including macros, are all capitals
// note the semicolons
#define MY_MACRO() printf("hello"); printf("world");
You would call it just as you have described:
MY_MACRO; // semicolon is optional on this line, because there is a semicolon at the end of the macro itself
