Custom KeyPad Problem
Ed_Banses
PostPosted: Thu Feb 08, 2007 8:44 am     Reply with quote
Hi all,
I am working now in a project where I have to interface a custom made KeyPad with a PIC.
KeyPad has each button connected straight to a PIC pin in one side and GND in the other side. There are 7 buttons.
I adapted the flexible keypad code to my project but I am getting problems.
The keys response is not good as some times I need to press more than once to get signal or keep the key pressed to read it.
Please find below my code:
#include <16F877A.h>
#device ICD=TRUE
#device   *=16
#fuses HS, PUT, NOWDT, NOBROWNOUT, NOLVP//,NODEBUG,  NOCPD, PROTECT
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#define DEBOUNCE     33
#define KEY_F1       PIN_B1
#define KEY_F2       PIN_B4
#define KEY_F3       PIN_B5
#define KEY_ENTER    PIN_B2
#define KEY_UP       PIN_B6
#define KEY_DOWN     PIN_B3
int8 key;
//Functions to drive the KeyPad
void kbd_init()
   port_b_pullups(true);
short int ALL_ROWS (void)
   if (input (KEY_F1) & input (KEY_F2) & input (KEY_F3) & input (KEY_ENTER))
      return (0);
      return (1);
int read_keypad()
   static BYTE kbd_call_count;
   static short int kbd_down;
   static char last_key;
   BYTE kchar;
   kchar = 0;
   if(kbd_call_count++ > DEBOUNCE)
      if(kbd_down) {
           if(!ALL_ROWS()) {
               kbd_down=FALSE;
               kchar=last_key;
               last_key = 0;
         if(!input (KEY_F1))
            last_key = 1;
         else if(!input (KEY_F2))
            last_key = 2;
         else if(!input (KEY_F3))
            last_key = 3;
         else if(!input (KEY_ENTER))
            last_key = 4;
         kbd_down = TRUE;
   return(kchar);
   kbd_init();
   printf("\n\rTry KeyKad");
      key = 0;
      while(key == 0){key = read_keypad();}
      printf("\n\rKey pressed was: %u",key);
I will appreciate any help from you.
Thanks a lot in advance.
Kind Regards,
Eduardo
PostPosted: Fri Feb 09, 2007 1:14 am     Reply with quote
The problem is that when you modified the code, you cut out some
lines that were needed. I compared your code to the original code
and fixed it. The lines that need to be added back in are marked
with comments below:
int read_keypad()
   BYTE kchar;
   kchar = 0;
      if(kbd_down) {
           if(!ALL_ROWS()) {
               kbd_down=FALSE;
               kchar=last_key;
               last_key = 0;
       if(ALL_ROWS()) {    // Add this line
         if(!input (KEY_F1))
            last_key = 1;
            last_key = 2;
            last_key = 3;
            last_key = 4;
         kbd_down = TRUE;
         }                // Add this line
   kbd_call_count = 0;     // Add this line
   return(kchar);
Ed_Banses
PostPosted: Fri Feb 09, 2007 3:48 am     Reply with quote
Thanks a lot PCM programmer!!!!
It works!!!!
You have save me again.
If you come to manchester at any time I will buy you a couple of pits ;)
Thanks again.
Kind Regards,
Eduardo
