Simple State Machine Concept
zilot
PostPosted: Wed Feb 07, 2007 10:23 am     Reply with quote
Here is some simple state machine concept, maybe someone finds it
as usefull.Any comment?
///////                   State Machine Concept                      ///////
///////   State Machine Name = STM                                   ///////
///////   State Machine States = STMST1, STMST2, ...STMST10          ///////
///////   State Machine Events = STMEV1, STMEV2,....STMEV10          ///////
///////                        Transitions                           ///////
///////   STMST1==>STMST5  for STMEV1                                ///////
///////   STMST1==>STMST3  for STMEV4                                ///////
///////   STMST2==>STMST1  for STMEV3                                ///////
///////   STMST2==>STMST10 for STMEV7                                ///////
///////   STMST3==>STMST4  for STMEV8                                ///////
///////   STMST3==>STMST7  for STMEV2                                ///////
///////   etc........................                                ///////
///////   When some extern event happens, one should call            ///////
///////   STMHandler (some event from defined set of events).        ///////
///////   Will State machine change or not current state             ///////
///////   depends whether transition is defined or not for current   ///////
///////   state and event passed as parameter to STMHandler().       ///////
//--------------------- Define states on State Machine STM -----------------
enum state{STMST1,STMST2,STMST3,STMST4,STMST5,STMST6,STMST7,STMST8,STMST9,STMST10}currentState;
//--------------------- Define events on State Machine STM -----------------
enum event{STMEV1,STMEV2,STMEV3,STMEV4,STMEV5,STMEV6,STMEV7,STMEV8,STMEV9,STMEV10}currentEvent;
//--------------------------- Define states handler ------------------------
void STMST1Handler(event eventHappened)
   switch(eventHappened)
      case STMEV1:   //Do some action
                     currentState=STMST5;
      case STMEV4:   //Do some action
                     currentState=STMST3;
     // Other cases
      default:       break;
void STMST2Handler(event eventHappened)
      case STMEV3:   //Do some action
                     currentState=STMST1;
      case STMEV7:   //Do some action
                     currentState=STMST10;
     // Other cases
      default:       break;
void STMST3Handler(event eventHappened)
      case STMEV8:   //Do some action
                     currentState=STMST4;
      case STMEV2:   //Do some action
                     currentState=STMST7;
     // Other cases
      default:       break;
void STMST4Handler(event eventHappened)
;  //Same as for other states transitions
void STMST5Handler(event eventHappened)
void STMST6Handler(event eventHappened)
void STMST7Handler(event eventHappened)
void STMST8Handler(event eventHappened)
void STMST9Handler(event eventHappened)
void STMST10Handler(event eventHappened)
//------------------------ Define state machine handler ---------------------
void STMHandler (event eventHappened)
    switch(currentState)
       case STMST1:  STMST1Handler(eventHappened);
       case STMST2:  STMST2Handler(eventHappened);
       case STMST3:  STMST3Handler(eventHappened);
       case STMST4:  STMST4Handler(eventHappened);
       case STMST5:  STMST5Handler(eventHappened);
       case STMST6:  STMST6Handler(eventHappened);
       case STMST7:  STMST7Handler(eventHappened);
       case STMST8:  STMST8Handler(eventHappened);
       case STMST9:  STMST9Handler(eventHappened);
       case STMST10: STMST10Handler(eventHappened);
       default:
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Wed Feb 07, 2007 5:29 pm     Reply with quote
Nested switch state machine. I think, it's the only type of state machine that can be practically implemented on a PIC with stable versions of the CCS compiler. As a result, this concept is very useful.
You might find this post interesting too http://www.ccsinfo.com/forum/viewtopic.php?t=28656
P.S. Here's a link to some standard state machine implementation concepts http://www.quantum-leaps.com/writings/PSiCC_Excerpts.pdf (chapter 3). It's outside the context of PICs, however all of these consepts have been implemented on ARM uCs.
zilot
PostPosted: Thu Feb 08, 2007 1:50 am     Reply with quote
I became frustrated when realised I cant do almost any modification of generated code from some embedded UML based software, to work with CCS compiler and PIC. There is visual state (IAR systems), but hard (maybe impossible) to be modified for CCS.
So seems this is for now only solution for some UML based work, but with no automatic code generation, just fingers and keyboard. Sadness but we must wait for some better times, or change controller and tools.
kender
PostPosted: Thu Feb 08, 2007 2:24 am     Reply with quote
Things should get better, after CCS debugs v4, and it will actually support function pointers.
Automatic code generation (ACG) is not a bad idea. For example, MS Visio Technical has UML stencils with all necessary fields. Visio is relatively cheap, compared to IAR suites. Visio supports Visual Basic for Applications (VBA). May be, ACG can be coded in VBA for Visio.
zilot
PostPosted: Thu Feb 08, 2007 5:15 am     Reply with quote
My first idea was to realise State Machine as structure, actually to define State Machine type, and to define States as type too. But was disapointed when realised that CCS doesnt support pointers to function. I wanted to encapsulate handler function into State, etc.... to be more generic, and to make easy for many State Machines definition in one project.
Dont like VB, just C, so this will be only way for now to deal with states.
treitmey
PostPosted: Thu Feb 08, 2007 9:17 am     Reply with quote
It does support pointer to function. At least it says it does.
http://www.ccsinfo.com/faq.php?page=pointer_to_function
jma_1
PostPosted: Thu Feb 08, 2007 1:04 pm     Reply with quote
Howdy,
If you like state machines, check out the compiler support for the Rabbit line of microprocessors. Search for 'costate' or 'cofunction'. It's interesting to view competitive products with built in multi-tasking support and features. I've never tried the CCS rtos, but the uC rtos available from Rabbit has been around for quite some time.
Cheers,
JMA
jma_1
PostPosted: Thu Feb 08, 2007 1:13 pm     Reply with quote
Greetings,
If you like UML (including 2.0) there are half a dozen free software tools which generate UML. The Eclipse framework alone has at least a dozen plug-ins for UML. One or more of these plug-ins supports code generation (c/c++ and/or java). Some of the commericial plug-ins, like Rational Rose will even do reverse engineering.
I have not researched anything recently, put ArgoUml was a freely available, stand-alone, java application, which allowed diagrams and code generation.
Cheers,
JMA
zilot
PostPosted: Fri Feb 09, 2007 2:12 am     Reply with quote
Till today I've tried Matlab RTW code generator for State Machine, and some models from simulink, VisualState IAR product, and Rhapsody. None of producted c codes cant be easily modified for PIC CCS, when calculate time eventualy I'll spend in code modification, and time I'll spend for manualy code writting, I'm on the same.
Rhapsody is very powerfull tool, you have complete image of whats happening in system, Object diagrams, Statecharts, Colaboration diagrams, good visual simulator of events and states in one word complete embedded UML environment. But rather to use with powerfull microcontroler (processor) and compiler than with PIC and CCS.
