LPP Guest
True RMS |
Posted: Fri Nov 09, 2001 5:11 am |
Dear all,
I am looking for routines to calculate TRUE RMS. I wrote one, but using float, it is very slow.
Thanks for any suggestions.
___________________________
Original Post ID: 1030 |
Titi Trandafir Guest
Re: True RMS |
Posted: Fri Nov 09, 2001 2:41 pm |
:=Dear all,
:=I am looking for routines to calculate TRUE RMS. I wrote one, but using float, it is very slow.
:=Thanks for any suggestions.
True RMS of a relatively well behaved waveform or more like a random signal ?
Original Post ID: 1040 |
LPP Guest
Re: True RMS |
Posted: Mon Nov 12, 2001 11:06 am |
:=:=Dear all,
:=:=I am looking for routines to calculate TRUE RMS. I wrote one, but using float, it is very slow.
:=:=Thanks for any suggestions.
:=True RMS of a relatively well behaved waveform or more like a random signal ?
Itīs like a random sinal.
Do you have any idea?
Original Post ID: 1068 |
LPP Guest
Re: True RMS |
Posted: Mon Nov 12, 2001 11:07 am |
:=:=Dear all,
Original Post ID: 1069 |
Yup!, this one is for CORDIC |
Posted: Mon Nov 12, 2001 2:08 pm |
:=:=:=Dear all,
:=:=:=I am looking for routines to calculate TRUE RMS. I wrote one, but using float, it is very slow.
:=:=:=Thanks for any suggestions.
:=:=True RMS of a relatively well behaved waveform or more like a random signal ?
:=Itīs like a random sinal.
:=Do you have any idea?
Cordic is ideal for fixed point arithmetic (that these microcontrollers can do very fast).You can use 8 bit 2's complement arithmetic. It can do very elegantly, squaring, averaging and then square rooting.
Original Post ID: 1076 |
PGMer Guest
Re: True RMS |
Posted: Wed Nov 14, 2001 10:05 am |
:=Dear all,
FYI: Analog Devices has a single chip solution for TRUE RMS to DC conversion w/dB out. With this chip it is possible to measure signals up to 8MHz. (part# AD637)
Original Post ID: 1097 |
LPP Guest
Re: Yup!, this one is for CORDIC |
Posted: Fri Nov 16, 2001 4:51 am |
:=:=:=:=Dear all,
:=:=:=:=I am looking for routines to calculate TRUE RMS. I wrote one, but using float, it is very slow.
:=:=:=:=Thanks for any suggestions.
:=:=:=True RMS of a relatively well behaved waveform or more like a random signal ?
:=:=Itīs like a random sinal.
:=:=Do you have any idea?
:=Cordic is ideal for fixed point arithmetic (that these microcontrollers can do very fast).You can use 8 bit 2's complement arithmetic. It can do very elegantly, squaring, averaging and then square rooting.
Sorry, I donīt know about Cordic. Could you send more informations?
Original Post ID: 1137 |
LPP Guest
Re: True RMS |
Posted: Fri Nov 16, 2001 4:56 am |
:=:=Dear all,
:=FYI: Analog Devices has a single chip solution for TRUE RMS to DC conversion w/dB out. With this chip it is possible to measure signals up to 8MHz. (part# AD637)
Iīm using AD736, but itīs very expensive. I want to change it to a software.
Original Post ID: 1138 |
Posted: Mon Nov 19, 2001 10:08 am |
Do a //www.google.com search for CORDIC. You will see a lots of hits.
Hope this helps.
:=:=:=:=:=Dear all,
:=:=:=:=:=I am looking for routines to calculate TRUE RMS. I wrote one, but using float, it is very slow.
:=:=:=:=:=Thanks for any suggestions.
:=:=:=:=True RMS of a relatively well behaved waveform or more like a random signal ?
:=:=:=Itīs like a random sinal.
:=:=:=Do you have any idea?
:=:=Cordic is ideal for fixed point arithmetic (that these microcontrollers can do very fast).You can use 8 bit 2's complement arithmetic. It can do very elegantly, squaring, averaging and then square rooting.
:=Sorry, I donīt know about Cordic. Could you send more informations?
Original Post ID: 1230 |
