RDA int problem
turbo2ltr
RDA int problem
PostPosted: Tue Feb 06, 2007 4:27 pm     Reply with quote
I'm sure it's something stupid but I can't seem to figure it out.
I enable the int_rda interrupt. My program works fine until a byte is received in the UART. Then the RDA interrupt runs continuously. I just send one byte, so after it services the interrupt once, it should clear the interrupt and it should not happen again. The disassembly shows that it clears the RXIF bit just before it exits. So why would it get triggered again if the flag is cleared?
I tried this with even an empty ISR routine and it still does it.
16F690
   enable_interrupts(global);
   enable_interrupts(int_rda);
   // main loop
      putc('-');
   }   // end while
#int_rda
void SerRxIsr()
   //   SerDataRdy = true;
        //   putc('+');
285:               #int_rda
286:               void SerRxIsr()
287:               {
288:               //   SerDataRdy = true;
289:               //   putc('+');
290:               }
291:
292:
   099    128C     BCF 0xc, 0x5
   09A    118A     BCF 0xa, 0x3
   09B    2834     GOTO 0x34
The output is a "-" stream until I tap a key, at which point I get nothing. If I uncomment the putc in the ISR, I get the "-" stream until I press a key, then I get a "+" stream. I never see the "-" again.
Any help is greatly appreciated.
Thanks,
Mike
PostPosted: Tue Feb 06, 2007 4:45 pm     Reply with quote
Read the 16F690 data sheet, in the Asynchronous USART section.
It says:
The RCIF interrupt flag bit will be set when there is an
unread character in the FIFO, regardless of the state of
interrupt enable bits.
This means you have to read the character in order to clear the interrupt.
Typically, getc() or fgetc() is used in the #int_rda isr to read the byte.
turbo2ltr
PostPosted: Tue Feb 06, 2007 5:42 pm     Reply with quote
I thought about that after I posted. I have some other timing critical interrupts and was hoping that I didn't have to read the byte right away, but could just set a flag to read later. Guess I'll at least pull it out of the register in the interrupt.
Thanks.
