Filter Issue
Filter Issue
PostPosted: Tue Jan 30, 2007 7:20 pm     Reply with quote
I have an array of 5 sensors. I am trying to filter it while I get it from the ADC. As in I am trying to make sure that the new value is not greater than the old value by more than10 %. I need to have the final array as an array of 16bit values.
Here is what I tried:
New Value = ((1-0.10)*(Old Value)) + (0.10*(New Value))
Here is what I did in the code:
int16 Sensor1[5];
int16 Sensor2[5];
double e =0.10;
int i;
I update all the values in Sensor2[5] by reading the 5 sensors with the ADC.
Then I do the following:
i=0;
for(i=0;i<5;i++)                   // Initialize Sensor1 Array.
Sensor1[i]=0;
for(;;)
//I update all the values in SensorOld[5] by reading the 5 sensors with the ADC.
i=0;
for(i=0;i<5;i++)
Sensor1[i]=((1-e)*(Sensor1[i]))+(e*(Sensor2[i]));
I would appreciate it if someone could find whats wrong with this code!
Thank you.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
Re: Filter Issue
PostPosted: Tue Jan 30, 2007 8:11 pm     Reply with quote
Anonymous wrote:
... As in I am trying to make sure that the new value is not greater than the old value by more than 10%. ...
You formula alone (which, I think, is an FIR filter) doesn't guarantee that the new value will be within 10% of the old value. Imagine a case, when the new value is more than 10 times bigger than the old value.
What's wrong with the output that the present code produces?
Neutone
Re: Filter Issue
PostPosted: Wed Jan 31, 2007 10:48 am     Reply with quote
int16 Sensor1[5];
int16 Sensor2[5];
double e =0.10;
int i;
i=0;
Sensor1[i]=0;
for(;;)
i=0;
for(i=0;i<5;i++)
Thank you.
That code looks like it was written to run on a PC with the extensive use of floating point and use of ambiguous variable types. It's faster to just filter by a binary fraction such as 1/8 or 1/16 and do all the math in Int16.
http://www.ccsinfo.com/forum/viewtopic.php?t=19509
