18f4550 port D weak pullups.
JED
PostPosted: Tue Jan 30, 2007 9:39 am     Reply with quote
In the data sheet for the 18f4550 it states there is a port D weak pull up option enabled with bit 7 of “port E register” 0xF84 (found on p66, p120 and p123 of the data sheet) which contains port E i/o and some other configuration bits. I try to set this bit but it doesn’t seem to happen. When I read the value of RDPU in my program it is always 0. My compiler is PCWH v3.249. Any help would be greatly appreciated.
Best regards.
#include <18f4550.h>
#DEVICE ICD=TRUE
#FUSES NOWDT
#FUSES NOLVP
#FUSES HS
#use delay(clock=10000000)
#BIT RDPU=0xF84.7 //define port d pullup enable bit
  RDPU=1; //turn on port d pullups
  delay_ms(1);
CCS PCH C Compiler, Version 3.249, 33321               29-Jan-07 23:03
               Filename: C:\Program Files\PICC\myStuff\TestPullupE.lst
               ROM used: 78 bytes (0%)
                         Largest free fragment is 31858
               RAM used: 5 (0%) at main() level
                         6 (0%) worst case
               Stack:    1 locations
0000:  GOTO   0030
.................... #include <18f4550.h>
.................... //////// Standard Header file for the PIC18F4550 device ////////////////
.................... #device PIC18F4550
.................... #list
.................... #device adc=8
.................... #DEVICE ICD=TRUE
.................... #FUSES NOWDT
.................... #FUSES NOLVP
.................... #FUSES HS//PLL
.................... #use delay(clock=10000000)
0004:  CLRF   FEA
0006:  MOVLW  06
0008:  MOVWF  FE9
000A:  MOVF   FEF,W
000C:  BZ    002C
000E:  MOVLW  03
0010:  MOVWF  01
0012:  CLRF   00
0014:  DECFSZ 00,F
0016:  BRA    0014
0018:  DECFSZ 01,F
001A:  BRA    0012
001C:  MOVLW  3C
001E:  MOVWF  00
0020:  DECFSZ 00,F
0022:  BRA    0020
0024:  NOP
0026:  NOP
0028:  DECFSZ FEF,F
002A:  BRA    000E
002C:  GOTO   004C (RETURN)
.................... #BIT RDPU=0xF84.7
0030:  CLRF   FF8
0032:  BCF    FD0.7
0034:  CLRF   FEA
0036:  CLRF   FE9
0038:  MOVF   FC1,W
003A:  ANDLW  C0
003C:  IORLW  0F
003E:  MOVWF  FC1
0040:  MOVLW  07
0042:  MOVWF  FB4
....................   RDPU=1;
0044:  BSF    F84.7
....................   delay_ms(1);
0046:  MOVLW  01
0048:  MOVWF  06
004A:  BRA    0004
004C:  BRA    004C
Configuration Fuses:
   Word  1: 0C00   NOIESO NOFCMEN HS PLL1 CPUDIV1 NOUSBDIV
   Word  2: 1E19   NOBROWNOUT NOWDT BORV20 NOPUT WDT32768 NOVREGEN RESERVED
   Word  3: 8300   PBADEN CCP2C1 MCLR NOLPT1OSC RESERVED
   Word  4: 0000   NOSTVREN DEBUG NOLVP NOXINST NOICPRT RESERVED
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
PostPosted: Tue Jan 30, 2007 10:29 am     Reply with quote
The pullups, require the port to be configured for dgital I/O. Every bit of port D, is multiplexed to the PSP peripheral, and this needs to be turned 'off', before the pull-ups can be enabled. Also the high few bits share with the ECCP.
setup_psp(PSP_DISABLED);
setup_ccp1(CCP_OFF);
should allow the pullups to work. They are _weak_ though (typically 50uA).
JED
PostPosted: Wed Jan 31, 2007 7:08 am     Reply with quote
Thanks for the reply Ttelmah. I did what you said and it works! The RDPU bit still always reads 0 but I have tested my board with a volt meter and when I set RDPU all pins on port d get pulled high and when I clear RDPU I read 0V, so it appears the pullups are working.
Best Regards.
PostPosted: Wed Jan 31, 2007 11:27 am     Reply with quote
If you look at section 10.5 of the data sheet, and the diagram below, entitled 'Register 10-1 PORTE register', you will see that the top bit is shown as 'R-0' - means it always 'reads' as a zero.
metalm2
PostPosted: Tue Apr 24, 2007 4:28 pm     Reply with quote
You have bad mapped the RDPU bit, because you direction this to PORTE and it must be in the TRISE register
so you must put in place of #BIT RDPU=0xF84.7, the corresponding: #BIT RDPU=0xF96.7
I do this, but i cannot activate pull ups, PORTD stands in HI impedance mode...
Another BUG detected in PCWH 3.222: When you use the PORT_B_PULLUPS(TRUE) function, this writes in a memory location that is wrong, because the bit RBPU is in INTCON2 and the functions writes in TRISE.5 that is a non-implemented register.
i already don't know why i still using this compiller...
metalm2
PostPosted: Tue Apr 24, 2007 4:57 pm     Reply with quote
correction:
the functions that works bad isn't port_b_pullups(), that is "setup_psp(PSP_DISABLED)" because this writes in F96.4 (TRISE register, bit 4) instead of the SSPCON register.
metalm3
PostPosted: Tue Apr 24, 2007 9:14 pm     Reply with quote
correction 2: RDPU is in PORTE (i was thinking this is in TRISE)
i am a living bug Evil or Very Mad Evil or Very Mad but i am sure that the "setup_psp(psp_disabled)" function is wrong because this writes in 0xF96.4 and that is an unused bit.......
