need help compiling c into hex file!!!
tom5467
PostPosted: Mon Jan 29, 2007 4:53 am     Reply with quote
i am really a beginner at programming a mcu. i have already wrote the c code to program my PIC16F877A microcontroller, but i can't figure out how to convert this c code to its hex counterpart.
i have downloaded a demo version of the ccs c compiler which needed an internet connection to operate. i compiles the program and it stated no error.
now what is the next step. Please help me!!!!!
Mark
PostPosted: Mon Jan 29, 2007 7:05 am     Reply with quote
Look in the project directory and you will find the hex file if it did indeed compile without errors.
tom5467
PostPosted: Tue Jan 30, 2007 8:15 am     Reply with quote
the ccs c compiler did reply that it had no errors, but i doubt that it had none. see my project is to create a fire protection system which consists of a main and remote unit, both with PIC16F877A. The main unit has four analog inputs to sense presence of fire hazard and three led outputs for warning purposes. one o/p activates a solenoid while still another o/p is sent to other PIC.
this is what the code looks like for the main unit_:
#include <16F877A.h>
#device *=16 ADC=10
#fuses HS
#fuses NOWDT
#fuses NOPROTECT
#fuses NOLVP
#fuses NODEBUG
#fuses NOPUT
#fuses NOBROWNOUT
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#define MY_TRISA 0b11111111
#define MY_TRISB 0b11111111
#define MY_TRISC 0b00000000
#define MY_TRISD 0b00000000
#define FOREVER 1
#define TEMP_LED PIN_C0 // out PIN 15
#define SMOKE_LED PIN_C1 // out PIN 16
#define LDR_LED PIN_C2 // out PIN 17
#define REMOTE_IND PIN_C6 // out PIN 25
#define FIRE_EXT_ACTIVATE PIN_D6 // out PIN 29
void initADC(void);
#pragma zero_ram // Clears all of the ram not used by the program
void main( void)
int16 ADC_0;
int16 ADC_1;
int16 ADC_2;
int16 ADC_3;
int16 temp;
int16 smoke;
int16 LDR;
int16 test;
ADC_0 = 0;
ADC_1 = 0;
ADC_2 = 0;
ADC_3 = 0;
temp = 665;
smoke = 1007.616;
LDR = 716.8;
test = 40.96;
delay_ms(500); // wait for voltages to stabilize
Set_Tris_A(MY_TRISA); // Port A's I/O
Set_Tris_B(MY_TRISB); // Port B's I/O
Set_Tris_C(MY_TRISC); // Port C's I/O
Set_Tris_D(MY_TRISD); // Port D's I/O
initADC();
while(FOREVER)
// beginning of testing of the lights
delay_us(50);
set_adc_channel( 3 );
delay_us(10);
ADC_3 = read_adc(); // Read in the value of the ADC
delay_us(50000);
if (ADC_3 > test)
output_high(TEMP_LED);
output_high(SMOKE_LED);
output_high(LDR_LED);
output_high(REMOTE_IND);
output_low(TEMP_LED);
output_low(SMOKE_LED);
output_low(LDR_LED);
output_low(REMOTE_IND);
//beginning of temperature sensing
delay_us(50);
set_adc_channel( 0 );
delay_us(10);
ADC_0 = read_adc(); // Read in the value of the ADC
delay_us(50000);
if (ADC_0 > temp)
set_adc_channel( 1 );
delay_us(10);
ADC_1 = read_adc(); // Read in the value of the ADC
delay_us(50000);
if (ADC_1 > smoke)
output_high(FIRE_EXT_ACTIVATE);
//beginning of smoke sensing
output_low(FIRE_EXT_ACTIVATE);
delay_us(10);
delay_us(50000);
if (ADC_1 > smoke)
//beginning of light sensing
set_adc_channel( 2 );
delay_us(10);
ADC_2 = read_adc(); // Read in the value of the ADC
delay_us(50000);
if ( ADC_2 < LDR )
//output_high(REMOTE_IND);
//output_low(REMOTE_IND);
// Purpose: Initializes ADC
// Precondition: None
// Postcondition: ADC is configured
void initADC(void)
setup_adc_ports(ALL_ANALOG); //
thankx for being patient enough for reading this!!! please let me know it u see any errors.[/code]
