CCS Bug !?!?!?
PICoHolic
CCS Bug !?!?!?
PostPosted: Mon Jan 29, 2007 3:25 am     Reply with quote
Plz lets consider the following simple code:
#include <16F877A.h>
#device adc=8
#FUSES NOWDT
#FUSES XT
#FUSES PUT
#FUSES NOPROTECT
#FUSES NODEBUG
#FUSES BROWNOUT
#FUSES NOLVP
#FUSES NOCPD
#FUSES NOWRT
#use rs232(baud=1200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_2(T2_DIV_BY_4,249,1);
   setup_ccp1(CCP_CAPTURE_RE);
   set_pwm2_duty(124);
   setup_ccp2(CCP_PWM);
   setup_vref(FALSE);
This code will generate a 1Khz PWM on CCP2.
When compiled using CCS v: 4.017 -> Nothing Exclamation Question
When compiled using CCS v: 4.013 -> PWM Shocked
Any thoughts?
CCS Technical Support does not monitor this forum on a regular basis. Please do not post bug reports to this form. All bug reports should be emailed to support@ccsinfo.com. Thank you.
PostPosted: Mon Jan 29, 2007 3:36 am     Reply with quote
Yes. Use 3.249.... Smile
The 4.xxx compilers, seems now to just about be starting to work. I have compiled three test programs, that previously would not work properly with earlier V4 compiler versions, and with 4.023, and they are at last producing working code. There are still problems with a lot of the 'new' stuff, but the compiler looks to at last have just about reached a possible 'beta' status in my mind. The versions before this, are not useable compilers, unless you are very lucky (look at the posts about this). 3.249, is a reasonably stable working compiler, and unless you 'need' one of the new features, would be the preferred choice.
PICoHolic
PostPosted: Mon Jan 29, 2007 4:17 am     Reply with quote
Wow Shocked that's dangerous !!
I tried it in 4.023, it works!
10x
