DS1307 with FORCE_HW (solved)
Philosopher
PostPosted: Sun Jan 28, 2007 8:13 am     Reply with quote
My I2C-communication works just fine until I try to activate the hardware with force_hw. It doesn't even get past the start()-command! Any ideas?
My setup:
CCS version 4.013
PIC16F874A at 20MHz
RTC DS1307
1k pullups on SCL- and SDA-lines (also tested with 10k)
An LCD-display to show the time
lcd_ks0066.h
#include <16F874A.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
//#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3)
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3,force_hw)
lcd_ks0066.c
#include "E:\Coding\Pic\LCD KS0066\lcd_ks0066.h"
#define    LCD_RS      PIN_E0
#define    LCD_RW      PIN_E1
#define    LCD_E      PIN_E2
int8 lcd_read_byte()
   int8 retval;
   output_high(LCD_RW);
   output_high(LCD_E);
   retval = input_d();
   output_low(LCD_E);
   output_low(LCD_RW);
   return(retval);
void lcd_send_byte(int8 data)
   while(bit_test(lcd_read_byte(),7));
   output_high(LCD_RS);
   output_d(data);
   output_high(LCD_E);
   delay_cycles(1);
   output_low(LCD_E);
   output_low(LCD_RS);
void lcd_init()
   int8 i;
   output_low(LCD_RS);
   output_low(LCD_RW);
   output_low(LCD_E);
   delay_ms(15);
   for (i=0; i<3; i++)
      output_d(0x38);
      output_high(LCD_E);
      delay_us(1);
      output_low(LCD_E);
      delay_ms(5);
   output_d(0x06);
   output_high(LCD_E);
   delay_us(1);
   output_low(LCD_E);
   delay_us(40);
   output_d(0x0E);
   output_high(LCD_E);
   delay_us(1);
   output_low(LCD_E);
   delay_us(40);
   output_d(0x01);
   output_high(LCD_E);
   delay_us(1);
   output_low(LCD_E);
   delay_ms(2);
   output_d(0x80);
   output_high(LCD_E);
   delay_us(1);
   output_low(LCD_E);
   delay_us(40);
   int8 hh=0, mm=0, ss=0;
   // SETUP
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // MAIN PROGRAM
   lcd_init();
   printf(lcd_send_byte, "Time ");
   i2c_start();      //THIS IS WHERE IT HANGS WITH FORCE_HW ACTIVATED
   i2c_write(0xD0);   //Write to DS1307
   i2c_write(0x00);   //Address 0
   i2c_write(0x56);   //Start oscillator, Seconds = 56
   i2c_write(0x34);   //Minutes = 34
   i2c_write(0x12);   //24-h, Hours = 12
   i2c_write(0x01);   //Day = 1
   i2c_write(0x26);   //Date = 26
   i2c_write(0x01);   //Month = 01
   i2c_write(0x07);   //Year = 07
   i2c_write(0x10);   //Square-wave out 1Hz
   i2c_stop();
   delay_ms(1);
   i2c_start();
   i2c_start();
   i2c_write(0xD1);   //Read from DS1307
   ss = i2c_read();
   mm = i2c_read();
   hh = i2c_read(0);
   i2c_stop();
   printf(lcd_send_byte, "%x:%x:%x", hh, mm, ss);
PostPosted: Sun Jan 28, 2007 9:46 am     Reply with quote
It might be a compiler problem. All v4.xxx versions are still to be considered beta releases and contain many bugs. That being said, you are using an old compiler version v4.023 is out already, have you tried the latest compiler version?
For production quality software I recommend you to use the last stable compiler release, v3.249.
Philosopher
PostPosted: Sun Jan 28, 2007 10:03 am     Reply with quote
So there is nothing wrong with my code then? Very Happy
PostPosted: Sun Jan 28, 2007 10:22 am     Reply with quote
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_vref(FALSE);
This is all CCS Wizard code. The setup_spi() statement shown
above in bold will shut down the SSP module. That includes
shutting down the hardware i2c. Delete that line.
Philosopher
PostPosted: Sun Jan 28, 2007 10:45 am     Reply with quote
Ahh.. that's it!
Thank you PCM programmer!
domdom
PostPosted: Fri Feb 16, 2007 6:51 am     Reply with quote
what type of LCD you are using? i am currently using LCD 2x16 connecting to ds1307.
can this code be used in my application?
based on the software given by philosopher, pin DB0-DB7 of LCD connecting to which I/O ports of PIC?
Philosopher
PostPosted: Fri Feb 16, 2007 12:13 pm     Reply with quote
I'm using a 4x16 display with a KS0066 controller chip. I believe that chip is compatible with HD44780.
You could use this code but I would recomend you to use the CCS or some other complete driver for this display instead. This is just me messing around.
If you use this code you should connect DB0-DB7 to port D.
