removing union
removing union
PostPosted: Sat Jan 27, 2007 6:26 pm     Reply with quote
i woul like to know how to remove the union in this short extract of code. i have no idea. any suggestion would great.
thanks
char rata;
union {
unsigned short cookie;
struct {
char LowByte;
char HighByte;
PostPosted: Sat Jan 27, 2007 11:18 pm     Reply with quote
It's tough to know what you want. What would you like to see after
the union is "removed" ?
Also, be aware that an "unsigned short" is an unsigned 16-bit integer
in most C compilers. But in CCS, a "short" is a 1-bit variable.
To translate an "unsigned short" from a normal C program to CCS,
you would change it to an "int16" in CCS.
PostPosted: Sun Jan 28, 2007 3:37 am     Reply with quote
Also, as posted, it also doesn't make any sense. The union has no 'name', so couldn't be accessed...
