WHUNG.JOHN Guest
LCD DISLPLAY QUESTION |
Posted: Sat Jan 27, 2007 10:47 am |
TODAY .
I WRITTEN A SAMPLE LCD DISPLAY PROGRAM.AND NOT USE LCD.C (LIBRARY PROGRAM).
I used lcd.c library program .display any value correct.
but i tried written lcd display,and writted into pic16f877 chip.
the lcd dont display any vlaue.
my writted program. follow as .
i dont find error.please help me again.
#include <16F877.h>
#use delay(clock=10000000)
#fuses NOWDT,HS
void del (void)
int j;
for (j=0;j<20;j++);
void en1(void)
output_high(pin_d0);
del();
output_low(pin_d0);
del();
void write_com(unsigned char C)
output_d(C);
output_LOW(pin_d1); en1();C<<=4;
output_d(C);output_LOW(pin_d1);en1();
void init_lcd1(void)
output_d(0x30); en1();
output_d(0x20); en1();
write_com(0x28);
write_com(0x08);
write_com(0x01);
write_com(0x0c);
//write_com(0x0F);
void write_data(unsigned char C)
output_d(C);
output_high(pin_d1); en1();C<<=4;
output_d(C);output_high(pin_d1);en1();
void pr(char x,char *y)
int i;
if (x==1)
write_com(0x80);
for(i=0;i<16;i++) write_data(' ');
write_com(0x80);}
{write_com(0xc0);
for (i=0;i<16;i++) write_data(' ');
write_com(0xc0);}
do {write_data(*y++);}
while(*y!='\0');
pr1(char t,char w)
write_com(0x80+t);
write_data(w);
char p[]="1234";
char k[]="5678";
output_low(pin_d0);
init_lcd1();
pr(2,p);
pr1(5,k);
Posted: Sun Jan 28, 2007 4:01 pm |
When you're a beginner, use an LCD driver that's already known to work:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
#fuses NOWDT,HS |
Also, use the NOLVP fuse. The default state in your #fuses statement
is the same as if you had the LVP fuse enabled. That's why it's
important to specify NOLVP.
A small number of people use a "low voltage programmer" that they
built by themselves. These people will use the LVP fuse.
Everyone else (about 99% of PIC users) should use the NOLVP fuse. |
