Interrupt being missed.
ch_dupre
PostPosted: Fri Jan 26, 2007 6:31 am     Reply with quote
I am currenly using timer3 to trigger an interrupt every 100ms. From time to time, I need to run a part of the program for 1ms which can't be interrupted. So I first disable and and then re-enable the timer interrupt 1ms later.
What happen if a timer overflow occurs when the interrupt is disabled? I suppose I just miss it. Is it possible to service the interrupt?
Thanks,
ch_dupre
Mark
PostPosted: Fri Jan 26, 2007 6:57 am     Reply with quote
You will get an interrupt when you reenable global interrupts.
