jfk1965
Help with RS232 problem. |
Posted: Wed Jan 24, 2007 6:36 am |
I'm having a problem with my RS232. To try to solve the problem I decided to send the data on one pin (PIN E1) of my18F4580 and read it back into another (PIN E2). I wrote the following small test program
#include <18f4580>
#fuses HS,NOPROTECT,NOLVP,NOWDT
#use delay (clock=20000000)
int vbatt,packv;
vbatt = 0x55;
#use rs232 (baud = 9600,float_high, bits = 8, xmit = PIN_E1,rcv = PIN_E2)
putc (vbatt);
packv = getc();
if I remove the packv = getc(); line the pic transmits fine, with the program as above the pic doesn't transmit at all.
What did I do wrong?
It's a pin to pin connection with a 1K pullup to the 5V supply, my compiler is version 3.245.
TIA
JFK[/code] |
Re: Help with RS232 problem. |
Posted: Wed Jan 24, 2007 7:35 am |
jfk1965 wrote: | I'm having a problem with my RS232. To try to solve the problem I decided to send the data on one pin (PIN E1) of my18F4580 and read it back into another (PIN E2). I wrote the following small test program
#include <18f4580>
int vbatt,packv;
vbatt = 0x55;
putc (vbatt);
packv = getc();
TIA
JFK[/code] |
You must understand getc() waits while receive data. Your data has been sent 1 line before, and it is too late for getc(). If You want to get something send by the same device, you must use receiving by interrupts. |
jfk1965
Posted: Wed Jan 24, 2007 8:11 am |
OK thanks I think I've got a grasp of it now. Can I test for a kbhit with an if statement before I use the getc?
I will try it
JFK |
Posted: Wed Jan 24, 2007 9:36 am |
You can, but you will never see the character. The 'point', is that you are using a 'software' UART on these pins. This means the compiler can only do one thing at a time. Receive a character, _or_ transmit a character. there is no buffering. To receive a character, the code has to either be waiting for it to arrive (in getc), or check kbhit, in the first half of the bit time. To have buffering (where the character is automatically held for you till you read it), you need to be using the hardware UART pins.
jfk1965
Posted: Wed Jan 24, 2007 10:30 am |
Ttelmah wrote: | You can, but you will never see the character. The 'point', is that you are using a 'software' UART on these pins. This means the compiler can only do one thing at a time. Receive a character, _or_ transmit a character. there is no buffering. To receive a character, the code has to either be waiting for it to arrive (in getc), or check kbhit, in the first half of the bit time. To have buffering (where the character is automatically held for you till you read it), you need to be using the hardware UART pins.
Thanks Ttelmah for that explanation,one more question if I may. To use the hardware UART is it just a case of changing the pins assignments for xmit and rcv in the #use 232 statement or do I have to do anything else like the setup_UART. Also will I need to use the 1K pull ups on the hardware UART like I did on the software uart or not?
thanks for your patience, I'm normally a power guy using pics to measure voltage and switch outputs based on the readings this is the first time I've used RS232 and it's provng a bit more difficult than I'd hoped.
JFK |
