Is MAX232 chip required??
weg22
PostPosted: Tue Jan 23, 2007 2:31 pm     Reply with quote
Hi all,
I am using the MaxSonar EZ-1 ultrasonic sensor. It outputs data in RS232 format. According to the 2nd page of the datasheet (see below), the RS232 voltages range from 0-5V and not -12V to 12V. Therefore, shouldn't I be able to grab data from it without using a MAX232 chip?
http://www.superdroidrobots.com/product_info/MaxSonar-EZ1-Datasheet.pdf
I was able to get data from it without any problems when integrating my PIC with a MAX232 chip, but when I hook it up directly to the PIC I get a bunch of weird ASCII characters.
Thanks in advance,
-weg
frequentguest
PostPosted: Tue Jan 23, 2007 2:53 pm     Reply with quote
Just a quick off-the-top-of-my-head answer without looking at the datasheet. Could the signals be inverted?
weg22
PostPosted: Tue Jan 23, 2007 3:10 pm     Reply with quote
What signals are you referring to? Are you suggesting that my Tx and Rx lines are reversed? If so, this is not correct or I wouldn't be seeing any data coming in.
SherpaDoug
PostPosted: Tue Jan 23, 2007 3:19 pm     Reply with quote
The usual MAX232 chip inverts the 0's and 1's. If you are using a software UART you can specify INVERT in the users232 setup line. Otherwise you can use any normal logic inverter.
PostPosted: Tue Jan 23, 2007 3:37 pm     Reply with quote
Look at their FAQ page. Scroll about 40% of the way down the page
to the section on "TX output", where they show a photo of a DB-9
connector.
http://www.maxbotix.com/MaxSonar-EZ1__FAQ.html
They say that the unit connects directly to the PC with a serial cable.
This means that the sonar unit has the equivalent of a MAX232 circuit
inside it (even though it uses 0 to 5v levels instead of -12v to +12v).
To amplify Sherpa Doug's comments, this means that if you use
the hardware UART in the PIC, then you must add an external inverter
chip to the Tx and Rx signals (a chip such as a 74HC04 or 74HCT04).
If you use a software UART, then you must use the INVERT option in
the #use rs232() statement. The hardware UART can't use the INVERT
option. It only works with a soft UART.
weg22
PostPosted: Tue Jan 23, 2007 3:41 pm     Reply with quote
Yep, that was it! Used the INVERT option and it worked perfectly! Thanks Sherpadog and PCM.
-weg
