Code help... Using Switches
Srig007
PostPosted: Mon Jan 22, 2007 1:03 pm     Reply with quote
I have a project that has two switches, a push button switch and a slider switch.
SwitchA = push button
SWITCHB = slide switch
I want to do the following using a combination of the two switches.
Everytime SwitchA is pressed (while keeping SWITCHB to logic high) I want it to increment a counter until it reaches a specified value, and then reset the counter to start all over.
But when the status of SWITCHB is logic LOW, regardless of the status of SWITCHA I want it to continuously increment the counter by itself.
I have no way to test this code, but if someone can please look at it and tell me if the code is correct I would really appreciate it, thanks in advance for your time.
I am using PIC16F877 as the microcontroller of choice.
#define SWITCHA    PIN_D0      // Push Button   --> Pull-up.
#define SWITCHB      PIN_D1      // Slide Switch --> Pull-Up
#define DEBOUNCE_PERIOD_IN_MS  10
#define DEBOUNCE_COUNT  2
void main ()
   Int Value;
   Value = 0
   While(1)
   wait_for_keypress();
   value++;
   if(Value == 1)         //Display 1 on Screen
      printf("1");
   if(Value == 2)
      printf("2");      //Display 2 on Screen
   if(Value == 3)
      printf("3");      //Display 3 on Screen and
      Value = 0         //Reset Counter
While(1);
Void wait_for_keypress(void)
   char icount;
   While(1) //waiting for switch to be released
      if(input(SWITCHA) == 1)&&(input(SWITCHB) == 1)
         icount++;
         icount = 0;
      if(icount == DEBOUNCE_COUNT)
      delay_ms(DEBOUNCE_PERIOD_IN_MS);
      if(input(SWITCHA) == 1)&&(input(SWITCHB) == 0)   //Slide Switch in Auto Mode
         Value = Value + 1;
   icount = 0
   While(1) //waiting for switch to bbe pressed
      if(input(SWITCHA) == 0)&&(input(SWITCHB) == 1)
            icount++;
            icount = 0;
            Value = Value + 1;
      if(input(SWITCHA) == 0)&&(input(SWITCHB) == 0) //Slide Switch in Auto Mode
         Value = Value + 1;
