PIC16F913 PWM question
jksor1234
PostPosted: Mon Jan 22, 2007 11:16 am     Reply with quote
I am using compiler version PCWH 4.020
I am trying to set up the PIC16F913 to output a PWM. When I use the CCS PIC Wizard and set up CCP1 as a PWM, it says the PWM output is on pin C2. However, in the datasheet it says the PWM output is on pin C5. Do I believe the datasheet or the PIC Wizard? My guess is the datasheet.
PostPosted: Mon Jan 22, 2007 5:20 pm     Reply with quote
There's no errata on the 16F913 data sheet at the Microchip site, so
pin RC5 should be correct, as you say.
