| View previous topic :: View next topic   |
			future
				| Detecting when timer2 is about to overflow. |
				 Posted: Sat Jan 20, 2007 11:58 am     |
I want to detect when Timer2 (prescaled and post scaled) is about to overflow and generate an interrupt.
I know I can read timer2, but I donīt know how to deal with the post scaler. Is there a readable counter?
Thank you. |
			kender
				| Re: Detecting when timer2 is about to overflow. |
				 Posted: Sat Jan 20, 2007 4:28 pm     |
				 	  | future wrote: | 	 		  | Is there a readable counter? |
Yes.  You can read any timer's counter with GET_TIMERx() function.  x is  a number of the timer. |
			future
				 Posted: Sat Jan 20, 2007 4:33 pm     |
				I thought that the postscaler would let the timer rollover N times before the interrupt flag come active.
Thank you. |
			ferrumvir
				 Posted: Sun Jan 21, 2007 3:48 am     |
Sorry, I've no help, I'm watching this thread as the issue interests me.
Why do you need to know when the interupt is about to occur, can you tell us why you need to do this and maybe we can think of an alternative solution to your underlying issue.
Cheers Scott |
			future
				 Posted: Sun Jan 21, 2007 6:59 am     |
				| The timer 2 is the 'software timers' base timing. When I load a new soft timer I want to know if there is an interrupt happening soon so I can add a count to it and have less jitter. |
			ferrumvir
				 Posted: Sun Jan 21, 2007 8:20 am     |
I think I understand what you are after, and I think this is the answer.
The trick is to only reset the timer with the updated values, in the interupt. In order to do this you'll need to some global variables.
psuedo code...
int reset_value;
#Int
void int()
  do update
  reset timer from reset_value
  set reset_value;
I hope you see how this avoids jitter, by allowing the last interupt to complete, before resetting the timer to the new values.
Hope that helps,
Cheers Scott |
