[RESOLVED] How to change the use of Tx I/O during execution?
franckcl
PostPosted: Fri Jan 19, 2007 8:07 am     Reply with quote
I am writing a test program for my product and during the test phase, I would like to change the Tx output (Serial communication) into a standard I/O port. Same question for Rx input.
The serial communication has been setup by using the #USE pragma.
thank you for your help.
Franck
franckcl
PostPosted: Fri Jan 19, 2007 9:06 am     Reply with quote
I have found ! here under the solution:
bit_clear(RCSTA1,7); // Serial port 1 disabled
bit_clear(RCSTA2,7); // Serial port 2 disabled
PostPosted: Fri Jan 19, 2007 10:22 am     Reply with quote
I like setup_uart() better than the direct register addressing.
setup_uart(FALSE, stream)   // disable uart
setup_uart(TRUE, stream)   // enable uart
Stream is an optional stream identifier.
I noticed this command also toggles the RCSTA.CREN (Continuous receive enable) bit which might be an improvement over your code.
