Problem with I2C and TMR0 int on 16F873
Mark DSylva
PostPosted: Fri Dec 13, 2002 10:33 am     Reply with quote
<font face="Courier New" size=-1>Hi,
I have a strange problem related to some I2C slave code I wrote for the 16F873.
Everything was working well, and then I decided to disable the INT0 interrupt which I had originally enabled and made a small interrupt routine for, as I didn't need it in my project.
After removing the first line below,
enable_interrupts(int_timer0); // enable timer0
enable_interrupts(int_timer1); // enable rx timer
enable_interrupts(INT_RB); // enable portB input change int
enable_interrupts(INT_SSP);
in the initialisation code for the processor, one of my I2C data responses to another processor fails with a clock stretch timeout.
All that's in the interrupt routine is this:
#int_timer0
timer0_int() // TMR0 overflow interrupt
// DEBUG_PIN = ~DEBUG_PIN; (this line not used now)
tmr0IntCtr++;
I don't have any idea what is causing this.
Does anyone have any ideas? I'm using PCM 3.104
Mark
</font>
___________________________
Original Post ID: 10033
keith
Re: Problem with I2C and TMR0 int on 16F873
PostPosted: Mon Dec 16, 2002 10:32 am     Reply with quote
Hi Mark,
Did you solve your problem. I am having a i2c problems as well and was wondering what you may have leart from this problem.
thanks
Keith
:=<font face="Courier New" size=-1>Hi,
:=I have a strange problem related to some I2C slave code I wrote for the 16F873.
:=Everything was working well, and then I decided to disable the INT0 interrupt which I had originally enabled and made a small interrupt routine for, as I didn't need it in my project.
:=After removing the first line below,
:= enable_interrupts(int_timer0); // enable timer0
:= enable_interrupts(int_timer1); // enable rx timer
:= enable_interrupts(INT_RB); // enable portB input change int
:= enable_interrupts(INT_SSP);
:= enable_interrupts(GLOBAL);
:=in the initialisation code for the processor, one of my I2C data responses to another processor fails with a clock stretch timeout.
:=All that's in the interrupt routine is this:
:=#int_timer0
:=timer0_int() // TMR0 overflow interrupt
:= // DEBUG_PIN = ~DEBUG_PIN; (this line not used now)
:= tmr0IntCtr++;
:=I don't have any idea what is causing this.
:=Does anyone have any ideas? I'm using PCM 3.104
:=Thanks
:=Mark
:=</font>
Original Post ID: 10068
Mark DSylva
PostPosted: Mon Dec 16, 2002 2:39 pm     Reply with quote
:=Hi Mark,
:=Did you solve your problem. I am having a i2c problems as well and was wondering what you may have leart from this problem.
:=thanks
:=Keith
No I didn't solve it. I just kept the INT0 interrupt enabled for now, I'll have to re-visit this problem in a few days.
Mark
Original Post ID: 10074
Derek
PostPosted: Fri Jan 10, 2003 3:41 pm     Reply with quote
My I2C slave code does okay on a F877, but when I ported the code to the F873, the I2C intterupt only responds every other time.
Do you guys think this is related??
Derek
:=#int_timer0
:= tmr0IntCtr++;
:=Thanks
:=Mark
:=</font>
Original Post ID: 10602
