Setting up WDT
sjharris
Setting up WDT
PostPosted: Tue Jan 09, 2007 2:52 am     Reply with quote
hello all in ccs forums.
could you help me set up a watch dog timer using the prescalers on a PIC 16F688.
I am not using Timer 0 in my program at all so I should be able to get the time out period to be as high as 30 seconds?
I do not fully understand the prescalers envolved with setting up the WDT so any and all help would be most appreciataed.
I would like to use the Watch Dog Timer to check that my program is running ok every 30 seconds, I think I understand that without the prescaler the reset is approx 0.47 seconds is this correct ?
If so how can I change to time out to be as high as 30 seconds (datasheet says 1ms to 268 s here -->
http://ww1.microchip.com/downloads/en/DeviceDoc/41203C.pdf
Thanks for any help in advance.
S Harris
PS Is this correct:-
setup_timer0(RTCC_INTERNAL|RTCC_DIV_1);
setup_counters(RTCC_INTERNAL, WDT_DIV_65536);
what would this give as a WDT reset?
thanks
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
Re: Setting up WDT
PostPosted: Tue Jan 16, 2007 4:59 am     Reply with quote
Those 2 lines do not setup the WDT. Research the setup_wdt(...) function.
