Interrupt ext_int_edge triggers backwards
Jacky
PostPosted: Mon Jan 15, 2007 3:40 pm     Reply with quote
I'm trying to read one of my robot sensors as an interrupt, it works as a software loop but the interrupt is backwards.
Condition: The robot is on a black surface PIN_RB0 HIGH, will turn low on a white surface.
This works:
if( !INPUT(LINE_L_DET2) ) {
  printf("\n\rLine Left Detect");
I tried to turn the above loop into an interrupt but I only get the interrupt when: Robot enters the white surface, Robot goes back to black surface = INTERRUPT
I tried switching ext_int_edge(INT_EXT,H_TO_L); but it will not change the outcome. I need the interrupt when the robot goes from black onto the white surface not the other way around.
Example Program, the Sensor is connected to RB0(INT_EXT):
#include <18F2620.h>
#device adc=10
//#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
//#FUSES HS   //External HighSpeed Clock
//#FUSES BORV21                   //Brownout reset at 2.1V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOSTVREN                   //Stack full/underflow will cause reset
#FUSES NOLVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOPBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOLPT1OSC                  //Timer1 configured for low-power operation
#FUSES NOMCLR                     //Master Clear pin enabled
#use delay(clock=8000000)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PC)
#use fast_io(b)
#use fast_io(c)
//Left Side of Sensor Array
#define LINE_L_DET1 PIN_B2  //IR Detector on Inside
#define LINE_L_DET2 PIN_B0  //IR Detector on Outside
#define LINE_L_EM PIN_B5    //Power for IR Emitter
#define LINE_L_DET PIN_B4   //Power On For IR Detector
#int_ext
void rb0__isr() {
  disable_interrupts(INT_EXT);
  printf("\r\n\r\nInterrupt\r\n");
   setup_oscillator(OSC_8MHZ);
   set_tris_a(0b00000001 );
   set_tris_b(0b00001111 );
   set_tris_c(0b00000000 );
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
//Turn Off All IR Emitters
   output_low(LINE_L_EM);
//All IR Emitters Off
   ext_int_edge(INT_EXT,H_TO_L);      // interrupt when robot enters the white border around the arena
   enable_interrupts(global);         //Enable Interrupts
   enable_interrupts(INT_EXT);        //Enable Interrupt in INT0
do {
output_high(LINE_L_DET);  //Turn on Power to IR Detectors
output_high(LINE_L_EM);   //Turn on Power to IR Emitters (they are always on to use interrupts)
} while (TRUE);
PostPosted: Mon Jan 15, 2007 4:04 pm     Reply with quote
ext_int_edge(INT_EXT, H_TO_L);
The first parameter is incorrect. See the manual.
http://www.ccsinfo.com/downloads.php
Jacky
PostPosted: Mon Jan 15, 2007 6:08 pm     Reply with quote
thanks, changed to:
ext_int_edge(0,H_TO_L);
and all works well now. Thanks
