pic sounds, how to do
anauta
PostPosted: Mon Jan 15, 2007 4:47 am     Reply with quote
I noticed that Roman Black's site was updated.
http://www.romanblack.com/picsound.htm
He has improved his btc sound encoder utility very much.
Now my question:
How to implement the hardware and software. His instructions are reasonably detailed regarding the HW side (I will experiment).
Yet how to do the software part? (output to pin X, timing, etc).
I just want to play a very short wav file (1 to 2 seconds).
PIC4520, CCS compiler 4.020.
Has anyone pulled it off?
Can I see it, please, can I? Wink
I would be very happy!
Greetings and thanks,
Auke
Imanjl
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Jan 15, 2007 11:15 am     Reply with quote
hey man,,,,,Im working on a same project but I use some type of DAC chip to generate the sound the thing that u want is Pwm DAC and i think this may help u ...
http://www.k9spud.com/traxmod/pwmdac.php
anauta
pic sounds, simple!
PostPosted: Tue Jan 16, 2007 6:24 am     Reply with quote
Thanks for yuor help.
The info you provided is not enough to get me started however (beginner, what can I say ;) ).
I am looking for a very simple system with minimal (extra) hardware to play a few seconds of low-fi sound.
Anyone?
Thanks,
Auke
Humberto
PostPosted: Tue Jan 16, 2007 6:59 am     Reply with quote
Did you see the excelent work posted by Mark in the Code Library ?
http://www.ccsinfo.com/forum/viewtopic.php?t=22010&highlight=
Humberto
anauta
pic sounds, simple!
PostPosted: Wed Jan 17, 2007 4:11 am     Reply with quote
Thanks Humberto,
It seems like a nice solution.
However, I need to play short wave files.
That is why I pointed to www.romanblack.com/picsound.htm.
So, how to play short audio (wave) samples?
Thanks,
Auke
yerpa
PostPosted: Wed Jan 17, 2007 4:32 pm     Reply with quote
I have some code for the 16F873 that will play 11 Khz 8-bit wav files from a small eight-pin flash memory chip. It includes a simple X-Modem interface to upload the files via serial port. You command the files to play by sending a byte to the serial port. If you are interested, I could post the code. It uses all of the 'F873 code memory. You cannot move it to the larger PIC16 chips because the *=16 directive slows it down too much. Someday I'd like to port the program to the PIC18 series so that I can add features.
anauta
PostPosted: Thu Jan 18, 2007 2:31 pm     Reply with quote
Hi yerpa,
Yes, I would like to see your code.
I want to port it to the PIC18 4520, using internal flash memory.
Thanks for your help,
Auke
CS
PostPosted: Thu Jan 18, 2007 7:05 pm     Reply with quote
Yes I would like to have this code too.
Currently I am using PIC16F917, it trigger a buzzer which can only had one sound.
I would like it to had a selection of sound too.
Do you had the hardware wiring too?
CS
yerpa
PostPosted: Fri Jan 19, 2007 3:55 pm     Reply with quote
I just posted the code to the "code" section of these forums. If someone can tell me how to attach a pdf file a message in this forum. then I will post the schematic. Thanks for your interest and sharing of ideas!
anauta
pic sounds, simple!
PostPosted: Mon Jan 22, 2007 4:53 am     Reply with quote
Thanks for the code, yerpa.
I shall give it a try!
Greetings,
Auke
