The next step of my project is to implement a bootloader for the 18f4525. I've done a search, and a lot of results came up for the 18f452, could I use the 18f452 bootloader for the 18f4525 using the int osc?
Thanks.
Posted: Sat Jan 13, 2007 8:33 am
Hello anonymous guest,
Be as vague as possible and expect to get an accurate response.
For starters, which bootloader are you referring to?
