"+OB" command line switch
mpfj
PostPosted: Mon Jan 15, 2007 7:14 am     Reply with quote
I'm using 4v020, and wish to compile my code to a .bin file, not .hex !!
I use the ocmmand line as follows ...
ccsc +FH +DF +OBbin +STDOUT main.c
The code compiles without any problems, and generates the binary file, but calls it "main.hex".
The manual states the "+OBxxx" should generate an output file with a .xxx extension. The xxx part appears to be ignored.
Can someone please confirm that the +OB command line switch does not work properly ? If so, I'll report it as a bug.
treitmey
PostPosted: Mon Jan 15, 2007 9:24 am     Reply with quote
I don't know if anyone is trying to do too much with V4.x yet
Perhaps that is why noone answered.
Have you thought about a conversion program bin2hex, hex2bin??
mpfj
PostPosted: Mon Jan 15, 2007 9:33 am     Reply with quote
The +OB switch doesn't work with 3v249 either ... I thought I'd try the latest version.
The compiler generates a binary file (as opposed to a hex file) ... it just gets the name wrong !?!
Good old CCS Crying or Very sad
CCS Technical Support does not monitor this forum on a regular basis. Please do not post bug reports to this form. All bug reports should be emailed to support@ccsinfo.com. Thank you.
