baffled by the bootloader
Piccolo
PostPosted: Wed Jan 10, 2007 4:56 pm     Reply with quote
using PCWH 3.249 with PIC18F6720
This is odd, and I hope someone can help.
I have a program that I load into the PIC via Epic programmer that writes some data to an external eeprom.
I have another program that I then load into the same PIC via Epic programmer that reads the data from the external eeprom.
so far, so good.
I then need to allow the user to change between the programs (in case the data written needs to be altered) so I implement a bootloader.
I place
[/code]#build(reset=0x200)
#build(interrupt=0x208)
#org 0x0000,0x01FF {} [code]
before the main of each program and compile both programs.
I install the first program via the bootloader and it installs and runs fine.
I then install the second program via the bootloader but it now does not read the data back anywhere near correctly.
If I load the first program (without the bootloader code using an Epic programmer)
and then load the second program either via the bootloader or via the Epic programmer it reads the data fine! I have no idea why this occurs.
The bootloader works fine for installing different versions of the second program.
Any idea where I should look to see why the second program cannot read the data?
I have searched the forum but have not found a match.
Any suggestions greatly appreciated.
Thank you in advance
PostPosted: Wed Jan 10, 2007 5:29 pm     Reply with quote
Might have something to do with the #fuse settings, are these the same in all your programs?
All bootloaders have limited capabilities for the fuses; setting a fuse from the bootloader is no problem, but some (or all) fuses can only be reset by an external programmer performing a full chip erase. It was implemented this way to prevent changing of the memory protection fuses.
Piccolo
PostPosted: Wed Jan 10, 2007 11:59 pm     Reply with quote
Yes, both sets of #fuses are identical
#fuses NOBROWNOUT,XT,WDT128,NOLVP
except program 1 has
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=UPort1)
while program 2 has
#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,stream=UPort2)
but these statements are after the #fuses,
The bootloader always connects through UPort1.
PostPosted: Fri Jan 12, 2007 10:32 am     Reply with quote
What bootloader are you using?
PostPosted: Fri Jan 12, 2007 10:39 am     Reply with quote
Should your staement not be
#ORG 0x7000,0x7FFF {}
