aodj
stdarg.h and variable parameters |
Posted: Wed Jan 10, 2007 3:15 am |
I'm trying to implement a subroutine that calls a variable number of arguments.
The routine is in the form scroll(9, 55, 55, 16, 36, 36, 31, 36, 55, 55); where the 9 denotes the number of variables, and the susbequent variable are all values within an array. The routine will take the first varaible (55 in this case) look it up in an array called led_map[] and return a hex value to ouput to my 7-segment display.
Now this is fine, I'm getting something output to my display, however, I only ever seem to load the first variable. Code: | void scroll(int a, ...)
char c;
va_list al;
va_start(al, a);
while(a--)
if(scrollcount == 124)
c = va_arg(al, char);
segs(seg_2, seg_3, c);
scrollcount = 0;
va_end(al);
The code should take the variable, and display it on the right hand segment of the 3 digit 7-segment display, whilst shunting the display one character to the left, to present a scrolling effect.
I have an interrupt that reads the locations of seg_1, seg_2 and seg_3 for the current output character every 250 us or so. The IF loop is in there to slow down the updates to the memory locations, so that it doesn't update it quickly and essentially show the final character.
This is with PCM 4.016 and for a 16F914 pic.
Can anyone show me where I've gone wrong? Additionally, when i compile it, I get a >>> Warning 207 Line 138(1,1): Code has no effect, referring to the line just after the final subroutine } bracket.
CCS Technical Support does not monitor this forum on a regular basis. Please do not post bug reports to this form. All bug reports should be emailed to support@ccsinfo.com. Thank you. |
Posted: Wed Jan 10, 2007 3:39 am |
First, the V4.xxx compiler versions up till now are all to be considered beta versions. I'm sorry to say so, but knowledge from the past major compiler upgrades learns us that it will take about 6 more months for CCS to release a stable compiler version.
Variable arguments are a new functionality in the V4.xx compiler. Like most new features at the current state it will contain bugs.
The most recent stable compiler version is v3.249 and I recommend you to use this unless you want to spend a lot of time searching for compiler bugs.
Second, when reporting problems make sure the problem still exists in the most recent compiler version. V4.016 is old, current version is 4.020. CCS provides the service to send you an email when new compiler versions are released http://www.ccsinfo.com/newsletters.php |
aodj
Posted: Wed Jan 10, 2007 3:56 am |
Old? Crikey, I only got it at the end of November! |
Posted: Wed Jan 10, 2007 6:00 am |
Normally, that would make it fairly new. However, the key is that V4, has only just been 'launched', and CCS, have a really annoying habit, of effectively doing their beta testing on the customers!. While this is happening, new versions appear every few _days_...
Currently, the latest releases of V4, are just about competitive with V3.249, using only 'V3' features. So far I have yet to find a 'new' (V4) feature that fully works. Some are just starting to show signs that they are getting close.
If you have a look in the code forum, there is a method shown for doing a sscanf (Ithink), using a 'work round', of passing a string containing the multiple values. While not perfect, this works, and if you pull 3.249, it'll get you going till a V4 version starts to really work...
