| Macro Explanation Please! |
Posted: Sun Jan 07, 2007 10:52 am |
I am using these wonderful macros that I found on the board to deal with individual i/o pins:
#define set_bit_var(x) bit_set(*(int8 *)(x >> 3), x & 7)
#define clear_bit_var(x) bit_clear(*(int8 *)(x >> 3), x & 7)
#define read_bit_var(x) bit_test(*(int8 *)(x >> 3), x & 7)
As a relatively new and curious programmer, I was wondering if anyone could explain to me the various asterisks that appear in the define statements as, although I do understand pointers, I am not sure quite why two asterisks and an 'int8' are needed here?!
Many thanks in advance!
John |
Posted: Sun Jan 07, 2007 10:58 am |
OK. The first '*', says 'use this pointer'. The second is a 'cast'. The little bit in the bracket, 'converts' the value that follows, 'into' a pointer of type 'int *' (pointer to an integer). Up to this point, what follows, is an integer. the bracketted bit, tells the compiler to treat this integer as if it was a pointer. The first *, then uses this as a pointer!.
| Thank you! |
Posted: Sun Jan 07, 2007 11:07 am |
Brilliant, a concise and crystal clear explanation - now my curiosity is satisfied - thank you very much!
Regards,
John |
