RC5 [Manchester] Decoding ....Does this Work ??
chriss2000
PostPosted: Tue Jan 14, 2003 8:39 am     Reply with quote
#include <16f876.h>
#Device ICD=TRUE
#bit T0IF=0xB.2
#bit INTF=0xB.1
#use rs232(BAUD=9600, xmit=pin_c6, rcv=pin_c7)
int newbit=0,ready=0,offset=1,i=0;
long count=0,code=0,abtast=75;
set_tris_A(0xFF);
set_tris_B(0xFF);
set_tris_C(0x00);
enable_interrupts(global); enable_interrupts(int_ext); ext_int_edge(H_TO_L);
while(1) {
while(ready==1)
if(i<14)
count=get_timer0();
if(count>=abtast)
newbit=input(Pin_A0);
code=code|newbit;
code<<=code;
abtast=abtast+111;
printf("\%c",code);
i++;
ready=0;
#int_ext
isr() {
disable_interrupts(int_ext); setup_timer_0(RTCC_DIV_16|RTCC_Internal);
set_timer0(0);
ready=1;
___________________________
Original Post ID: 10682
Hans Wedemeyer
Re: RC5 [Manchester] Decoding ....Does this Work ??
PostPosted: Tue Jan 14, 2003 9:17 am     Reply with quote
no...!
Not sure about your actual code, but these items are critical
You did not initialize Timer 0.
Do this BEFORE you release the global interrupt.
set_tris_A(0xFF);
set_tris_B(0xFF);
set_tris_C(0x00);
enable_interrupts(global); // let it rip
// your code here
No need to stop interrupts in int_ext just set timer0() and the flag
#int_ext
isr() {
set_timer0(0);
ready=1;
I'm not sure what your need is when setting Timer0 to zero,
I expect you are trying to measure something...If the external input is what's being measured then I don;t see how it will work !
If you Get_Timer0() before resetting it, you will be able to measure the time between the last interrupt and the current interrupt. Assuming Timer0 does not overflow. !
int DeltaTime=0; // some global var.
#int_ext
isr() {
DeltaTime = Get_Timer0(); / time since last event
set_timer0(0);// start measuring next event
ready=1;
Original Post ID: 10685
chriss2000
PostPosted: Wed Jan 15, 2003 2:59 pm     Reply with quote
#include <16f876.h>
#Device ICD=TRUE
#bit T0IF=0xB.2
#bit INTF=0xB.1
int newbit=0,flag=0,offset=1,i=0;
#int_ext //allow ext interrupt
isr() //Interrupt Service Routine
disable_interrupts(int_ext); //disable interrupt on Pin B0 [until the next signal
set_timer0(0); //Set Timer 0 to zero
flag=1; //Set Interruptflag to 1
set_tris_A(0xFF);
set_tris_B(0xFF);
set_tris_C(0x00);
setup_timer_0(RTCC_DIV_16|RTCC_Internal); //Timer 0 Setup, counts up with 62,5kHz
//Teilung: When the counter has the value 1, 16us have left
enable_interrupts(int_ext); //Allow ext Interrupt on Rb0
enable_interrupts(global); //Allow Global Interrupt
ext_int_edge(H_TO_L); //Wait for falling edge--> then jump to Interrupt Service Routine
while(1) //As long as True -->Make Main
while(flag=1)
if(i<14) //14 Bit Code-->scan 14 times
count=get_timer0(); //Get counter time
if(count>=abtast) //If counter time is greater than the value were i want to scan my signal-->scan the Pin A0
newbit=input(Pin_A0); //get the bit value of Pin A0
code=code|newbit;
code<<1; //Shift the input values in my integer
abtast=abtast+111; //count up my scan value
i++;
delay_ms(80); //80ms delay to wait for the beginning of the next signal
enable_interrupts(int_ext); //allow ext Interrupt on Pin B0
flag=0; //Set The Interrupt Flag to Zero to get out of the cycle
abtast=75; //The Timer Value 75 is the same as 1,2 ms and i need that time to scan my bit in the 3/4 bit size
i=0;
Original Post ID: 10728
