Zigbee starter Guest
ICD Driver Problem |
Posted: Thu Jan 04, 2007 12:27 am |
I am a beginner, I am trying to learn Zigbee using CCS - Wireless - ZMD development kit.
I first popped in the compiler CD, installed all the software it had on it. I connected my ICD-U40 to my development board and then connected it to my PC using the USB port. It says found new hardware and is asking me to install the drivers, I asked it to search for drivers in the CD-ROM but no luck. For some reason the ICD-U40 Drivers did not install. I tried to reinstall the drivers from D:/USB-Driver ..... still no luck :(
When I run ICD.exe my COM port is on 3 and when I press connect it says "Could Not connect: Cannot detect ICD type"
Why cannot I install such a simple driver? Did I miss something ?
A quick response would be greatly appreciated!
Thank you |
Zigbee Starter
Desperate |
Posted: Thu Jan 04, 2007 11:46 am |
Thanks for a quick reply .... but unfortunately I tried that procedure last night but still had no luck.
Here is a screenshot of what happens when I try to specify the location of the usb drivers
it says the driver cannot be reached
One more thing:
When I try to run the setup_drivers.exe ..... I get this screen
I never get any dialog boxes as the .exe file mentions ..... I just get the "found new hardware wizard" ........ After a while I just click "NEXT" and it tells me that it finished installing the drivers but it does not
Please guide me on how to fix this problem  |
Posted: Thu Jan 04, 2007 1:40 pm |
I can't help any more because I don't have an ICD-U40. I use the
Microchip ICD2. I suggest that you telephone CCS tech support. |
Zigbee Starter
Posted: Thu Jan 04, 2007 5:18 pm |
Do you know where can I download the standalone 'ICD Control Program" ? I tried the ccsinfo.com/downloads but no luck ..... is that program discontinued?
Because I think I need to change the COM Port to "ICD-U40" .... mine is stuck in COM port 3
I will up CCS tomorrow offices are closed now.... any help by then will be greatly appreciated! Thank u! |
Posted: Thu Jan 04, 2007 5:29 pm |
Quote: | Do you know where can I download the standalone 'ICD Control Program" ? |
You can download it from this page:
http://www.ccsinfo.com/downloads.php
Scroll down to where it says:
Quote: |
ICD Software
Here is the current software for the CCS ICD modules (all ICD-U and
ICD-S units are supported). This stand-alone software allows you to
in-circuit serially program flash Microchip PICmicro� MCUs using the
CCS ICD modules. |
Quote: | mine is stuck in COM port 3 |
I don't have the CCS IDE, so I can't help you directly, but in MPLAB
in the setup window for the ICD2, it has a drop-down box labeled
"Com Port". It has choices for
Quote: |
USB
Com1
Com2
Com3 |
I have it set for USB, because that's how I'm connecting the ICD2 to
my PC. |
Zigbee Starter
Posted: Thu Jan 04, 2007 11:05 pm |
contacted the Technical Support and got a fix ..... worked like a charm!
Quote: | In your PICC directory there should be a USB TOOLS ditrectory. In that directory find the .INF file
and right click on it and select INSTALL. |
In case someone else has the same problem, this should help  |
